RT-N66U keeps giving me limited access
Dec 12 16:37:50 miniupnpd[476]: received signal 15, good-bye
Dec 12 16:37:50 miniupnpd[485]: HTTP listening on port 47965
Dec 12 16:37:50 miniupnpd[485]: Listening for NAT-PMP traffic on port 5351
Dec 12 16:37:50 disk monitor: be idle
Dec 12 16:38:01 crond[369]: time disparity of 2076037 minutes detected
Dec 12 17:08:03 kernel: SKIPPED false Type 1 Radar Detection. min_pw=17 pw_delta=0 pri=52197 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 1864, = 31min 4sec. Detected pulse index: 4
Dec 12 17:08:58 kernel: eth1: received packet with own address as source address
Dec 12 17:08:59 kernel: eth1: received packet with own address as source address
Dec 12 17:24:03 kernel: SKIPPED false Type 1 Radar Detection. min_pw=36 pw_delta=0 pri=52139 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 960, = 16min 0sec. Detected pulse index: 2
Dec 12 17:36:04 kernel: SKIPPED false Type 1 Radar Detection. min_pw=28 pw_delta=0 pri=52187 fm_min=0 fm_max=0 nconsecq_pulses=3. Time from last detection = 720, = 12min 0sec. Detected pulse index: 2
Dec 12 17:58:30 pppd[431]: Serial link appears to be disconnected.
Dec 12 17:58:31 WAN Connection: Fail to connect with some issues.
Dec 12 17:58:31 stop_nat_rules: apply the redirect_rules!
Dec 12 17:58:36 pppd[431]: Connection terminated.
Dec 12 17:58:36 pppd[431]: Modem hangup
Dec 12 17:59:21 pppd[431]: Timeout waiting for PADO packets
Dec 12 18:00:37 pppd[431]: Timeout waiting for PADO packets
Dec 12 18:01:52 pppd[431]: Timeout waiting for PADO packets
Dec 12 18:01:57 rc_service: httpd 359:notify_rc reboot
Dec 12 18:01:57 pppd[431]: Unable to complete PPPoE Discovery
Dec 12 18:01:57 kernel: Attempt to kill tasklet from interrupt
Dec 12 18:01:57 FTP Server: daemon is stoped
Dec 12 18:01:57 Samba Server: smb daemon is stoped
Dec 12 18:01:57 WEBDAV Server: daemon is stoped
Jan 1 00:00:07 syslogd started: BusyBox v1.17.4
Jan 1 00:00:07 syslog: module ledtrig-usbdev not found in modules.dep
Jan 1 00:00:07 syslog: module leds-usb not found in modules.dep
Jan 1 00:00:07 kernel: klogd started: BusyBox v1.17.4 (2014-11-04 21:30:58 CST)
Jan 1 00:00:07 kernel: start_kernel
Jan 1 00:00:07 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Tue Nov 4 21:34:02 CST 2014
Jan 1 00:00:07 kernel: CPU revision is: 00019749
Jan 1 00:00:07 kernel: Determined physical RAM map:
Jan 1 00:00:07 kernel: memory: 07fff000 @ 00000000 (usable)
Jan 1 00:00:07 kernel: memory: 08000000 @ 87fff000 (usable)
Jan 1 00:00:07 kernel: Built 1 zonelists. Total pages: 585216
Jan 1 00:00:07 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
Jan 1 00:00:07 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 00:00:07 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 00:00:07 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Jan 1 00:00:07 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Jan 1 00:00:07 kernel: Using 300.000 MHz high precision timer.
Jan 1 00:00:07 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 1 00:00:07 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:07 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:07 kernel: PCI: Initializing host
Jan 1 00:00:07 kernel: PCI: Reset RC
Jan 1 00:00:07 kernel: PCI: Fixing up bus 0
Jan 1 00:00:07 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Jan 1 00:00:07 kernel: PCI: Fixing up bridge
Jan 1 00:00:07 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Jan 1 00:00:07 kernel: PCI: Fixing up bus 1
Jan 1 00:00:07 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Jan 1 00:00:07 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Jan 1 00:00:07 kernel: PCI: Fixing up bus 2
Jan 1 00:00:07 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:07 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jan 1 00:00:07 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:07 kernel: highmem bounce pool size: 64 pages
Jan 1 00:00:08 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 1 00:00:08 kernel: Physically mapped flash: CFI does not contain boot bank location. Assuming top.
Jan 1 00:00:08 kernel: number of CFI chips: 1
Jan 1 00:00:08 kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Jan 1 00:00:08 kernel: Flash device: 0x2000000 at 0x1c000000
Jan 1 00:00:08 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 00:00:08 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 00:00:08 kernel: 0x00040000-0x01fe0000 : "linux"
Jan 1 00:00:08 kernel: 0x0016e470-0x01980000 : "rootfs"
Jan 1 00:00:08 kernel: 0x01fe0000-0x02000000 : "nvram"
Jan 1 00:00:08 kernel: 0x01ee0000-0x01fe0000 : "jffs2"
Jan 1 00:00:08 kernel: Found an serial flash with 0 0KB blocks; total size 0MB
Jan 1 00:00:08 kernel: sflash: found no supported devices
Jan 1 00:00:08 kernel: dev_nvram_init: _nvram_init
Jan 1 00:00:08 kernel: u32 classifier
Jan 1 00:00:08 kernel: OLD policer on
Jan 1 00:00:08 kernel: Netfilter messages via NETLINK v0.30.
Jan 1 00:00:08 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Jan 1 00:00:08 kernel: ipt_time loading
Jan 1 00:00:08 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:08 kernel: net/ipv4/netfilter/tomato_ct.c [Nov 4 2014 21:33:24]
Jan 1 00:00:08 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:08 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:08 kernel: Warning: unable to open an initial console.
Jan 1 00:00:08 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:08 kernel: ctf: module license 'Proprietary' taints kernel.
Jan 1 00:00:08 kernel: et_module_init: passivemode set to 0x0
Jan 1 00:00:08 kernel: et_module_init: et_txq_thresh set to 0x400
Jan 1 00:00:08 kernel: bcm_robo_enable_switch: EEE is disabled
Jan 1 00:00:08 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Jan 1 00:00:08 kernel: wl_module_init: passivemode set to 0x0
Jan 1 00:00:08 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Jan 1 00:00:08 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 00:00:08 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Jan 1 00:00:08 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jan 1 00:00:08 kernel: SCSI subsystem initialized
Jan 1 00:00:08 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c027d000
Jan 1 00:00:08 kernel: NTFS (with native replay) support included
Jan 1 00:00:08 kernel: optimized: speed
Jan 1 00:00:08 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan 1 00:00:09 stop_nat_rules: apply the redirect_rules!
Jan 1 00:00:10 WAN Connection: Fail to connect with some issues.
Jan 1 00:00:11 kernel: scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
Jan 1 00:00:11 kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Jan 1 00:00:11 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 1 00:00:12 dnsmasq[358]: warning: interface ppp1* does not currently exist
Jan 1 00:00:12 RT-N66U: start httpd
Jan 1 00:00:12 syslog: Generating SSL certificate...
Jan 1 00:00:14 disk monitor: be idle
Jan 1 00:00:14 miniupnpd[390]: HTTP listening on port 35271
Jan 1 00:00:14 miniupnpd[390]: Listening for NAT-PMP traffic on port 5351
Jan 1 00:00:14 start_nat_rules: apply the nat_rules(/tmp/nat_rules__eth0)!
Jan 1 00:00:15 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan 1 00:00:15 kernel: nf_nat_rtsp v0.6.21 loading
Jan 1 00:00:15 dhcp client: bound 192.168.1.100 via 192.168.1.1 during 259200 seconds.
Jan 1 00:00:15 pppd[431]: pppd 2.4.7 started by Admin, uid 0
Jan 1 00:00:16 pppd[431]: Connected to 00:30:88:00:00:07 via interface eth0
Jan 1 00:00:16 pppd[431]: Connect: ppp0 <--> eth0
Jan 1 00:00:16 pppd[431]: CHAP authentication succeeded
Jan 1 00:00:16 pppd[431]: peer from calling number 00:30:88:00:00:07 authorized
Jan 1 00:00:16 pppd[431]: local IP address 81.147.168.80
Jan 1 00:00:16 pppd[431]: remote IP address 217.32.142.6
Jan 1 00:00:16 pppd[431]: primary DNS address 213.120.234.38
Jan 1 00:00:16 pppd[431]: secondary DNS address 217.32.171.22
Jan 1 00:00:16 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Jan 1 00:00:16 rc_service: ip-up 446:notify_rc stop_upnp
Jan 1 00:00:16 miniupnpd[390]: received signal 15, good-bye
Jan 1 00:00:16 rc_service: ip-up 446:notify_rc start_upnp
Jan 1 00:00:16 miniupnpd[476]: HTTP listening on port 37020
Jan 1 00:00:16 miniupnpd[476]: Listening for NAT-PMP traffic on port 5351
Jan 1 00:00:16 rc_service: ip-up 446:notify_rc stop_ntpc
Jan 1 00:00:16 rc_service: ip-up 446:notify_rc start_ntpc
Jan 1 00:00:16 rc_service: waitting "stop_ntpc" via ip-up ...
Jan 1 00:00:19 WAN Connection: WAN was restored.
Jan 1 00:00:20 rc_service: ntp 477:notify_rc stop_ntpc
Dec 12 18:02:40 rc_service: ntp 477:notify_rc restart_upnp
Dec 12 18:02:40 miniupnpd[476]: received signal 15, good-bye
Dec 12 18:02:40 rc_service: ntp 477:notify_rc restart_diskmon
Dec 12 18:02:40 disk monitor: be idle
Dec 12 18:02:40 miniupnpd[485]: HTTP listening on port 38777
Dec 12 18:02:40 miniupnpd[485]: Listening for NAT-PMP traffic on port 5351
Dec 12 18:03:21 crond[361]: time disparity of 2076123 minutes detected
There's a couple of WAN connection failures and a reset of the n66 there. Clear the log and then look again after a failure.
Just got limited access:
Dec 13 16:45:30 pppd[431]: Serial link appears to be disconnected.
Dec 13 16:45:34 WAN Connection: Fail to connect with some issues.
Dec 13 16:45:34 stop_nat_rules: apply the redirect_rules!
Dec 13 16:45:36 pppd[431]: Connection terminated.
Dec 13 16:45:36 pppd[431]: Modem hangup
Dec 13 16:45:46 pppd[431]: Connected to 00:30:88:00:00:07 via interface eth0
Dec 13 16:45:46 pppd[431]: Connect: ppp0 <--> eth0
Dec 13 16:45:46 pppd[431]: CHAP authentication succeeded
Dec 13 16:45:46 pppd[431]: peer from calling number 00:30:88:00:00:07 authorized
Dec 13 16:45:46 pppd[431]: local IP address 81.129.228.103
Dec 13 16:45:46 pppd[431]: remote IP address 217.32.142.6
Dec 13 16:45:46 pppd[431]: primary DNS address 213.120.234.38
Dec 13 16:45:46 pppd[431]: secondary DNS address 217.32.171.22
Dec 13 16:45:46 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Dec 13 16:45:47 rc_service: ip-up 1079:notify_rc stop_upnp
Dec 13 16:45:47 miniupnpd[1015]: received signal 15, good-bye
Dec 13 16:45:47 rc_service: ip-up 1079:notify_rc start_upnp
Dec 13 16:45:47 miniupnpd[1109]: HTTP listening on port 56860
Dec 13 16:45:47 miniupnpd[1109]: Listening for NAT-PMP traffic on port 5351
Dec 13 16:45:47 rc_service: ntp 477:notify_rc stop_ntpc
Dec 13 16:45:49 WAN Connection: WAN was restored.
That's you losing your internet connection.
All phone lines got filters? Does it drop when phone rings? Try master socket? Ask the usual stuff when broadband drops.
Yes using micro filter.
Connection used to drop when phone rang with the free BT modem/router it doesn't now with this setup but now I keep getting limited access and that rarely happened on the BT modem/router.
I changed it back to the BT modem/router and has been working fine, might return N66U back to amazon and get my money back as there doesn't seem to be any clear reasons why I'm getting this limited access.
You've certainly got an issue somewhere and it looks like it's your side. Unfiltered phone, bad internal phone line wiring, dodgy phone extension etc are all possible.
