RT-N66U possible security issue
hakatit
Hello,
So I've had this issue for a while. It's not a big security issue but it does bother me. Basically I am unable to log out of my Dark Knight completely. I'll give example to repeat, and explain more:
1) log in to router, make change, etc
2) log out of router
3) close browser tab
4) open new browser tab, and direct to router IP address
5) do whatever you like, without being tested for password again!
RMerlin told me via Email some time ago that I had to log out for 60 seconds, however it seems to make no difference. I can log out for days, close all tabs or just one. The only time this is not true is if I reboot the PC.
I'm on Ubuntu 13.04 (same happend on 12.10) and use Chrome browser. I see the same issue from My Android tablet as well. Chrome does not save my passwords, I dismiss the question each time.
Limitations are:
If I reboot the PC I am prompted to log in again.
If I attempt to login from another device, then all works properly. I'm asked to log out of current session, and if it is inactive (closed) or I've logged out, I can then log in from another location. Finally at that point I will have to login from the PC again as expected. This does not fix the issue that if one logs out from the current device then goes back to it that they are not tested again.
I've seen this issue on .270 builds, .354 and the latest .370. Today I spent 30 minutes telling the Asus Technical support of this issue just to be told to RMA it.
I'm confident that this problem existed before I ever did anything to the Router, but I have installed DD-WRT, Merlin and eventually came back to the stock builds. The DD-WRT builds did not have this issue, the Merlin and Asus ones do.
I realize that this is a small issue, however it does mean that if someone can obtain control of my PC, be it remotely or in person, that they can do anything they like to my router settings. My concern is in the former that someone who could gain remote access could then fully disable the firewall.
I would love to know if it is just me or if others experience this same issue. I've used Netgears and Linksys in the past and always immediately after clicking Logout am challenged to log in again. Most of those have in-activity timers as well.
There's nothing wrong with your router.
1. Open a single chrome tab.
2. login to your router
3. logout of your router
4. go to the chrome history tab on the upper right of your screen
5. Clear your browsing data (all of it) "since the beginning of time"
6. close your chrome browser and wait 1 minute
7. open a chrome browser and test it but don't login
8. From this point on, only login to your router via "incognito mode"
9. Or just use firefox and have it delete your history and cookies upon exit (closing browser).
Ok, but I can make changes. I get what you're saying but I can return, no-login and make changes. The Router should not allow this. All other Routers I've worked with don't do this.
I will, but my point is I shouldn't have to do anything different. It should just log me out without requiring that I use incognito mode or clear histories. Again, Every other Router I've used, Netgear, linksys all do this without me having to jump through hoops. Hell, even with DD-WRT on this router, it works as expected.
Your browser is caching the username and password, and sending it back to the router until you close it. It's not the router's fault, it's how HTTP AUTH works by design. HTTP is a stateless protocol, so when confronted with a login request (for example for every single image you load on the router's page), it has to resubmit the username/password. It does the same if you tell the router you are logged off - next time you request a page, the browser is asked for a password, and it simply sends it back.
