RT-N66U Version 3.0.0.4.378.6065
wouterv
2015.05.29
Japan only version
[Please note] This version changed the login username and password authentication method. After firmware updated, please press the reset button more than five seconds to reset the router to avoid some compatibility issues.
Security fixes:
1. Enhance the login authentication strength and fixed CSRF related issues.
New feature:
1. Added client list view button on network map and help administrator easily monitor all client connection status.
As discussed in other threads: 3.0.0.4.378.6065 is released for a whole range of Asus routers.
As seen before it is released as "for Japan only".
Experiences of the past learned that this release may anyhow be generic for all regions.
I have installed the firmware on my RT-N66U (Europe, the Netherlands).
Installation went smooth, with a hard-reset in between.
I noticed one glitch: after intial setup of the wireless settings, the router at some point forgot those settings and reverted the wireless settings back to default.
After re-entering the wireless part it seems all ok.
As discussed before: the way router firmware gets upgraded shall be enhanced. It is still not a task for dummies or the majority of router users around the world.
For those curious: the wireless driver for the RT-N66U is not changed in this version, still 6.30.163.2002 (r382208) as introduced with firmware version 3.0.0.4.376.3657.
The new logon screen is not very convinient on small screens and seems to ask for logon more often than before after setting changes.
The new "View List" button brings up a Client overview popup that doesn't bring much extra.
It is still often confused in number of actually connected clients.
I say it again: adding Merlins wireless site survey would be more beneficial and adds more than the still confused Client overviews.
Often I do see a follow-the-cursor tooltip, eg "USB Flash Disk". I guess after the cursor is hoovered over some part of the screen the tooltip sticks to the cursor untill you select another configuration screen.
I am not sure what else is updated, for sure some cosmetics and under the hood enhancements, at least it keeps the RT-N66U in pace (as far as possible) with the other router models.
It's the same driver version but a different build date than the 3657's, so something was tweaked it seems.
ASUSWRT RT-N66U_3.0.0.4 Thu May 28 11:47:54 UTC 2015
gildo@RT-N66U:/tmp/home/root# wl ver
6.30 RC163.2002
wl0: Apr 23 2015 11:36:25 version 6.30.163.2002 (r382208)
