RT-N66U VLAN on 1 LAN port
aurelijusb
I'm using RT-N66U router and Asus-merlin firmware 376.49_5.
I share my internet connection to my neighbourhood via LAN interface. Is it possible somehow that this one LAN interface will be isolated and he will not be able to see my wifi and LAN devices? Maybe use VLANs or smth? Or maybe somehow to configure DHCP and share LAN IPs from different subnet?
The answer is yes it can be done with scripts.
I don't know about others, but the reasons I have ignored your question are:
(1) Using the keywords you have used in your post, you can find others posts where solution(s) exist by using the forum search on this site.
(2) I have nothing to add to those posts that you will find using words you already have.
