RT-N66U WLAN problems with latest build 380.58
bmn1
Hello forum members.
I bought the router RT-N66U and install the latest merlin firmware. (380.58)
All devices in my WLAN work great together with the new router.
So far so good....a small problem is still there.
Now i try to connect via my mobile phone (OnePlus ONE - Android 5.1.1) to the RT-N66U.
Connection iss successful, the wireless icon appears on the upper ledge.
But... the mobile radio remains active, and don´t turn off.
...so the data traffic continues over my mobile radio.
If I turn off the mobile radio connection manually - the connection jumps instantly over to WLAN RT-N66U.
This behavior is not normal, is there any solution?
What can I do to fix the problem? Is there a setting I can change?
