RTAC68U with two switches
cluelessfb
Hi all,
Is it possible to connect two switches to Asus RTAC68U, as i would like to have one PoE switch in one room and a switch located in another room? Would this result in any complications?
That should not be a problem. It's quite a common configuration. Just make sure that you don't also cross-connect each switch together as that would create a "loop" :eek: (well, more a sort of triangle :D).
