RTRMON RTRMON v2.2.3 -Nov 16, 2025- Monitor your Router's Health (New: Wireguard, AMTM, Network Conn/Bandwidth/Diag + Port Scanner + Speedtest) - CLOSED
Could you please copy the exact output you get with errors and all? I can see if I can write a crazy filter to get rid of it all. That might be a good bandaid in the interim.
Sure:
ASUSWRT-Merlin RT-AX86U_PRO 3004.388.8_4 Sun Nov 17 19:18:01 UTC 2024
admin@RT-AX86U_Pro:/tmp/home/root# echo 2 > /proc/sys/net/ipv4/conf/wgc1/rp_filter
admin@RT-AX86U_Pro:/tmp/home/root# speed="$(/jffs/addons/rtrmon.d/speedtest --format=csv --interface=wgc1 --accept-license --accept-gdpr 2>&1)"
admin@RT-AX86U_Pro:/tmp/home/root# echo $speed
[2025-08-02 17:38:26.379] [error] Error: [0] Cannot open socket [2025-08-02 17:38:26.435] [error] Error: [0] Cannot open socket [2025-08-02 17:38:26.510] [error] Error: [0] Cannot open socket [2025-08-02 17:38:26.555] [error] Error: [0] Cannot open socket [2025-08-02 17:38:26.610] [error] Error: [0] Cannot open socket [2025-08-02 17:38:26.611] [error] Error: [0] Cannot open socket [2025-08-02 17:38:26.631] [error] Error: [0] Cannot open socket "AltusHost B.V. - Stockholm","5235","11.9958","0.0235","0","29754059","28028942","125619336","244406707","https://www.speedtest.net/result/c/388bc087-58b8-4553-8003-c6c38c8e9db6","1","14.7404","7.25051","9.85","247.991","9.92288","2.0673","8.865","33.693","11.915","12.009"
The error part is before the first "
Sure:
Could you try:
echo $speed | sed 's/^[^"]*//'
I'm not seeing any ill effects, so I updated Beta 3... please give it a shot if you had success?
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/master/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Could you try:
Looks great!
I will continue to search for a proper fix for the ipv6 bind issues and let you know if I find anything useful.
Awesome! Thanks for your excellent help with this, @ZebMcKayhan!!
I think I've found a way around it... ipv4 and ipv6 are very different and I don't claims to really know what I'm doing. But the
ip rule add from <wgcX ipv4> lookup wgcX prio 10
makes ipv4 work, the same is not true for ipv6 equivalent. However, adding
ip -6 rule add from all oif wgcX lookup wgcX prio 10
seems to do the trick for ipv6, both ping and speedtest.
For ping, only the target ip type fix is needed but for speedtest both are needed as ipv4 seems required for connection to ookla and then ipv6 for the test servers.
Unfortunately the ipv6 fix does not work for ipv4 either so this must mean that the packet formation must differ or something.
WOW! That's great stuff! I'll get this implemented. You rock! :)
Looks like this tweak has to be made as well on the rule removal:
ip -6 rule del prio 10
OK, I've made those changes to this latest version of Beta 3, and eliminated the sed cleanup (which I may actually add back in later, because it could help clean up other random garbage I've noticed in the past), but this would be a good test for you! :)
No good
From looking at the code it looks like you commented the ipv4 fix and added the ipv6 fix but as I said, for speedtest both are needed. Ipv4 to get the stuff from ookla otherwise we get the configuration error and no test and the ipv6 fix to take care of test server.
No good
Ahhhh I thought the one ring would rule them all! I'll add the other one back in as well.
I did modify the script locally by
-removing the # on line 3863
-add
ip rule del prio 10 >/dev/null 2>&1
before line 3875
Then it works beautifully:
No errors and I get an ipv6 capable server so the test is ipv6 over wgc1 according to the speedtest binary wishes. I think this is the best we can do until we can force speedtest over ipv4
-add
before line 3875
OK... I've made the necessary changes in Beta 4. Please see if everything continues to function if you don't mind? :)
Thanks! This version works just the same as my local edit. Great work!
Thank you for all your help troubleshooting this, and making some great recommendations to get around the Ookla Speedtest binary! :)
On the heels of a VPNMON-R3 release, here's the latest v2.2.0 of RTRMON! The biggie with this one is the compatibility of monitoring your Wireguard connections, along with using them with Speedtests, or seeing exactly what connections are happening on these WG tunnels! Enjoy!
What's new!?
v2.2.0 - (August 3, 2025)
- MINOR:
This release adds compatibility with Wireguard connections! New functionality has been added under: Page 2 - Network connections, now adding any Wireguard connections to the bottom of the list. Page 4 - Speed Test, now allowing you to speed test your WAN, VPN and Wireguard connections. Page 6 - Top 10 Network/Bandwidth connections, now showing established connections running across your Wireguard tunnels. Operations Menu, now showing additional keyboard options to allow you to quickly jump to a Wireguard speed test.
- PATCH: Many, many behind the scenes additions, optimizations and fixes, but could probably use a lot more! But hey it works! :)
- PATCH: Minor fixes and adding some more dev/nulls around certain commands to keep occasional messages from popping up in the main UI.
- PATCH: Added the rp_filter compatibility statements per @ZebMcKayhan for during use of the speedtest. Added additional ip rule filters to handle IPv6 as it the output was displaying errors and causing some display issues. Thanks so much for your help with this, Zeb!
Download Links (Or update directly within RTRMON or AMTM):
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/main/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Significant Screenshots:
Much of the UI has been touched to handle the new Wireguard functionality. As you can see below, the Operations menu has shortcuts for WG speedtest and network stats.
What's new!?
- MINOR:
Minor update today bringing compatibility to the RT-BE92U. ;)
What's new!?
v2.2.1 - (August 24, 2025)
- PATCH:
Added compatibility for the RT-BE92U line of routers
- PATCH: Fixed Operations Menu display problem that presented itself when no VPN slots were active, but WG slots are active.
Download link (or update directly within AMTM/RTRMON):
None today!
More optimizations in this upcoming version... releasing this as a beta first to ensure nothing looks odd from your end(s). Major work was done on Page #2 - WAN/LAN/VPN/WG stats. I'm especially interested to see that this is still displaying everything correctly for those who use private IP VPN/WG connections.
What's new?
v2.2.2b1 - (TBA)
- PATCH:
Fixed some of the logic to cut down on the VPN/WG slot calls for external public IP address/city validation, and re-use those same values if they have not changed. This would help bring down the amount of regular network noise that the script generates while running.
- PATCH: In the process of cutting down these IP address/location calls, a lot of duplicate code around these functions was cleaned up so that RTRMON runs faster and leaner, and provides slightly more accuracy around stats.
- PATCH: Fixed the banner menu showing whether VPN or WG or both VPN/WG are available for speed tests on page #4 depending on what slots are active.
Download link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/develop/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Unfortunately not this time... it was all a back-end overhaul.
What's new?
v2.2.2b1 - (TBA)
- PATCH:
Download link:
Here is what I experienced:
If you go to the screen to view Top 10 and it says that statistics are not current and you select C it puts an X in the WAN, LAN , VPN but doesn't do so for WG and you are left looking at the message please wait. After a while I broke out of RTMON. Tried twice same result. However if I used the option to update WAN, LAN, VPN & WG individually it did update the statistics.
What's new?
v2.2.2b1 - (TBA)
- PATCH:
Download link:
Missing OVPN1 on a couple of screens. OVPN1 currently is seeing some traffic.
Also seeing the hang on Top 10 gathering WG as previous;y reported by @CaptainSTX
Beta 2 is out... with a few more fixes! Thanks much to @CaptainSTX and @scootertramp for their valuable feedback! :)
What's new!?
v2.2.2b2 - (TBA)
- PATCH: Fixed some of the logic to cut down on the VPN/WG slot calls
- PATCH: Fixed OVPN1 stats not showing due to some incorrect variable naming. Thanks to @scootertramp for reporting!
- PATCH: Fixed the timing issue around the iftop command on the Top 10 Network Connections and Bandwidth Stats page #6. What was happening was that iftop would be waiting for any kind of network traffic, and on a low or unused VPN/WG slot, would just sit there until something came through. Now, the timeout command will kill iftop after 15 seconds of use, while iftop is now given the command to do its thing within 10 seconds, which still gives you a decent snapshot of what kind of traffic is happening during that time. Thanks to @CaptainSTX for reporting this!
Download link:
