When I run it, it returns "Guatemala City". I'm afraid you're blocking that ip-api domain somehow. Once you figure that out and whitelist it, RTRMON should run as normal.If I did it correctly, then it throws the same error.
Make any headway?Okay, thanks, I'll continue investigating with this lead. Thanks again!
What DNS services are you using? You might want to show some settings for both skynet and AGH. Are you doing country blocking? Are you seeing anything in your syslogs in the router UI when you try to go to that ip-api site? Might want to start a separate thread here in the addons section, to see if we can pull together and help you with this.No, I added the site to the whitelist in Skynet and AdGuard Home, but it's still the same.
If you're talking about WXMON, that is also using the ip-api site... which is probably why that doesn't work for you either.But something is blocking me because in amtm I use the script to see the weather and it also gives me an error, it doesn't see my country.
Unfortunately I don't use AGH, and wouldn't know how to troubleshoot if it's somehow blocking a site. Maybe first try an NSLOOKUP from the prompt, and see what that gives you?These are the ones I use in AdGuard Home.
Yeah, that looks much better! I see city names!I think it's working now!!! Can you confirm that for me, Viktor?
Whooo! Glad to make your day! I didn't do anything - it was ALL you! LOLWeather Report is working now too. I don't know what happened; all I was doing was adding your blocklist to Skynet, and it worked. Maybe your list helped. Things happen with equipment. Thanks, Viktor, for your interest in helping.
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/main/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Welcome To SNBForums
