Hello,
what i'm trying to achieve is running router's default DNS with "Forward local domain queries to upstream DNS".
But also running some kind of adblocker on separate ip on the router also.
So that way i can direct clients in DHCP settings to that alternative url.
There is a way to have diversion running on default routers ip and then one another, but both instances, as far as I understand it, need to run filtering.
And honestly I would just like to have default functionality of the dns of the router without it going through the diversion at all, just for the gained unnoticeable speed benefit.
I was able to use https://github.com/JACK-THINK/SCRIPTS-BOOTLOADER-FOR-ASUS-ROUTER/ to get ad block home installed and working, but only on router's ip, so no "Forward local domain queries to upstream DNS". This also means losing amtm. I have no Idea how to actually move it to another IP, i think i would somehow need to create interface for it or something.
I was not able to get pihole running, but i did not try very hard so far honestly
- I not even studied this https://www.snbforums.com/threads/installing-pihole-directly-on-asus-router.57262/page-3 yet
