Schedule guest network daily?
slash84
Is there a way to automatically enable the guest network from say 7pm to 10pm nightly, without having to log into the router to enable it each time. I know I can do this using parental controls on my main ssid, but I'd like to use the guest ssid if possible.
The parental controls also work with devices connected to a guest network. So you can activate the guest network as unlimited and implement the time limit via parental controls.
Thanks for the suggestion. Seems like a waste to have the guest ssid broadcasting permanantly when it will only be use 2-3 hours nightly. :(
