Scribe Scribe won't install
rwheaton1
OK..something really odd is going on. My router updated to the new FW 3006.102.4. I was looking at the logs on the ASUS GUI and Skynet log was not showing anything but a message that there was an error. I should have screen shot it. Anyhoo, I proceeded to uninstall Scribe UI and Scribe. Rebooted....No problems...worked perfectly. Now, I'm trying to install Scribe and I see a quick message before being put back to the menu that it (Scribe) detected an installed version and it exits installation. So, I checked the jffs/scripts folder and I don't see it. I'm not sure what to do next. AMTM does not show it installed. Here are screenshots:
I really don't want to wipe my router for this...any ideas?
If you need me to look or find something....I know how to get around but I'm not an expert so maybe a little instructions would be helpful LOL
Thank You!!
Didn't have to search too far for it either.
If you've moved from stock firmware or Merlin 3004 you may find a factory restore and manual rebuild is warranted.
I ran the commands and rebooted. AMTM shows Scribe and Scribe UI installed now. ASUSWRT GUI is updated and no errors. Everything is right as rain. :)
Thank you!
