Hello,
I am using an ASUS-AC87U with latest merlin firmware, in a LAN environment, to have extra layer protection. The original ASUS firmware does not seem to support to plug in a LAN switch port as WAN port. So I flashed a Merlin firmware, with static IP configured. I have a few ASUS AC87U recently configured like this and all are experiencing the same issue.
After setup completion, all devices under this router, keep disconnecting.
I would appreciate it if you could advise the possible causes and how to fix it.
Here is the ping output of the Windows attached to this network.
Reply from 172.217.164.110: bytes=32 time=4ms TTL=48
Reply from 172.217.164.110: bytes=32 time=14ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 172.217.164.110: bytes=32 time=5ms TTL=48
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
