selective routing with two openvpn clients running
rostar99
I would like to route certain ports to openvpn client 2 and certain IPs to openvpn client 1. Has anyone had any success selectively routing with two different openvpn clients running simultaneously?
Thanks in advance
Thanks in advance
I normally run selective routing for OpenVPN Client 1 through HMA to USA.
I have just connected OpenVPN Client 2 through HMA to Asia, and manually entered:
ip route add default via 10.200.1.80 dev tun12 table 300
ip rule add fwmark 128 table 300
ip route
XXX.XXX.XXX.1 dev eth0  scope link
10.8.0.2 dev tun21  proto kernel  scope link  src 10.8.0.1
10.8.0.0/24 via 10.8.0.2 dev tun21
10.88.8.0/24 dev br0  proto kernel  scope link  src 10.88.8.1
XXX.XXX.XXX.0/22 dev eth0  proto kernel  scope link  src XXX.XXX.XXX.123
10.200.0.0/22 dev tun11  proto kernel  scope link  src 10.200.1.8
10.200.0.0/22 dev tun12  proto kernel  scope link  src 10.200.1.80
127.0.0.0/8 dev lo  scope link
default via 92.14.80.1 dev eth0
and when I tag my laptop to use route table 300
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 10.88.8.115 -j MARK --set-mark 128
it routes traffic to Asia until I remove the PREROUTING entry (or set MARK=0)
I can't see why individual ports couldn't be selectively routed in this manner.
Regards,
Can you specify the solution
I have just got selective routing to work on my AC66U by following the 'Selective Routing with Asuswrt-Merlin' thread.
And would like to introduce a second openvpn client. The code in the post above does not help me a lot. (I am very new to this scripting stuff)
Any help would be appreciated.
