services-stop not working
bmn1
Hello,
I created a file "/jffs/scripts/services-stop" that should execute the file "/jffs/scripts/fake-hwclock save", but this isn't working.
Manually starting the script works, it creates a file /jffs/fake-hwclock.data and appends the line correctly.
After rebooting, "/jffs/scripts/services-start" gets executed, but services-stop doesn't even show up in my log files.
/jffs/scripts/services-stop:
#!/bin/sh
Permissions were set with:
chmod a+rx /jffs/scripts/*
Edit: I'm using an Asus RT-AC68U with the latest Asuswrt-Merlin 380.57
Sorry for bumping my thread.
Is this a bug in the latest Asuswrt firmware or did I something wrong?
I would check the content of fate-hw lock. Maybe you can post here?
Can't post it right now, since I'm not at home.
Content was created fine when I ran it manually.
The problem is the script doesn't get started at restarting or shutting the router down and on again.
Edit: I thought this is a core functionality of Asuswrt-Merlin, hoped to get an idea from Merlin. :)
Solved it.
I'm really sorry for opening this thread, problem was following:
I saved the scripts with Notepad++ as unix file.
Creating them with vi made it work!
