Settings - discover network clients / Epocam OBS
Pandabeer35
Dear All,
As beginner / user of 1 AX88U (main) and 2 AX92U (Aimesh points) - I try to solve some issues
I use Epocam for OBS Streaming - in a Fritz! network is working flawless - I can use my Iphone as wireless cam and it's detected without any problem by OBS. If I do the same in my house network with the ASUS router(s), I experience problems - the wireless Iphone cam is not detected. Both (laptop and Iphone are on the same Wireless network)
Which settings do I have to change so this will work? I see the same problems with detecting other clients in explorer - they are not showing up, but every client is in the same workgroup (like my NAS, Raspberry Pi etc) If I enter the direct address in the address bar of explorer - then I'm able to explore the files etc in the 'network neighberhood'
Can somebody help me? I'm using the latest stock firmware for AX88 (3.0.0.4.386_42095) and the latest beta on AX92 (3.0.0.4.386_42095)
Thank you in advance
Br,
Peter
