Shibby+VPN+ 2 router help
endimion
OK I'm in!!!!
I am the happy owner of an RT-N66U flashed with shibby tomato-K26USB-1.28.RT-N5x-MIPSR2-101-AIO-64K
I did that
http://www.shadowandy.net/2012/03/asus-rt-n66u-tomatousb-firmware-flashing-guide.htm
and that
http://wiki.hidemyass.com/Tomato_OpenVPN_Setup
and it worked great so far as a proof of consept
now I would like more info to fine tune my set up
1st
I would like to have either some advice and/or documentation on the WiFi set up.... because i'm kind of new to all this options of configuration....
2nd
(that might be a vpn forum question so i'll do a post there too)i sat up the vpn on openVPN as shown on the tut..
it's kind of working...
my set up right now is a dsl modem/router box from my ISP and my RT-N66U behind it and my XB on the asus router and Wi-Fi devices connecing to either the dsl BOX or the assus router depending on what location I want to be in.
now I know my set up is shaddy since I was just testing if it works.
My dsl BOX has limited options... I can put it in bridge mode and have my asus router do all the routing that's one quick easy fix.... and that would work for me if I can have 4 WiFi connection... 2 2.4Ghz and 2 5Ghz connection each one going either through the VPN or not through the VPN.. I'd have something like that:
WiFi2.5_VPN, WiFi2.5_local, WiFi5_VPN, WiFi5_local and my Eth going through VPN...
is that possible??? Looks like it with all the Vlan option and all but not sure how to hack it alone...
now if not possible (and I'd rather keep the dsl BOX routing too since it has an integrated NAS on it which I can't on the network if he box is in bridge mode) I know i have some limited control over the DHCP table with the dsl BOX.. I'd like to know if I can keep it routing with a table going from 192.168.1.10 to 192.168.1.20 and have the asus with a dedicated IP on the BOX routing with a table 192.168.1.30 to 192.168.1.40 with the XBox having a fixed IP...
If that works it would be the best but I need some help to be sure I'm not missing something.... tomato has so much more administrative option than factory firmware it's overwhelming :P
now 3rd and last question
can I set up openVPN with a bunch of VPN server address to chose from and it automatically logs in the fastest one... or an easy solution to enter several server IPs and quickly switch???
Hoppefully I will have more feedback on that post than I did on the last one :D
thank you all and see you on the other side
ok still no luck I see
still no clue on the wifi tweaking to have the best throughput and coverage etc but beside that I moved forward and that's what I did
I sat up the DSL modem/router box from the ISP like that:
IP local 192.168.0.254
submask 255.255.255.255
DHCP table 192.168.0.40-50
I locked the asus RT-N66U router MAC address to 192.168.0.60
and I DMZed that address on the DSL modem/router
now on the asus RT-N66U
IP local 192.168.0.1
submask 255.255.255.0
Gateway 192.168.0.254
DHCP table 192.168.0.2-9
I locked the XBox 360 MAC address to 192.168.0.2
on the XB
I put the IP as 192.168.0.2
gateway 192.168.0.1
I did some port triggering on the asus like that:
Port 88 (UDP)
Port 3074 (UDP and TCP)
Port 53 (UDP and TCP)
Port 80 (TCP)
and ticked
enable UPnP
enable NAT-PMP
inactive rules cleaning
cleaning interval 600 second
cleaning threshold 20 redirection
secure mode
LAN
My problem is I can connect to the WiFi on both the DSL modem/router and the ASUS router and everything is fine. I'm currently on the ASUS typing that post and I'm behind a US VPN showing a US IP when I test it on speetest or pingtest. and a French one corresponding at my fix IP provided by my ISP when I use the wifi from the DSL modem/router
************ MY PROBLEM *********************
My xbox is working fine on hulu netflix or other in OS apps but the connection test shows a NAT error (NAT status moderate) and gaming and VoIP is terrible or non existent
PLEASE HELP or at least say HI... no answer what so ever here on tom's hardware or tomatoUSB forums lol :P
You will need to bridge your modem (assuming it allows you that), otherwise you will be double-NATting (router + modem), and it will cause issues.
is there really no other way ???
I have an integrated NAS on the DSL modem/router
at least can I set up 2 LANs one going through the VPN and one straight through the DSL modem/router in bridge ???
Maybe you should go to shibby place and ask him.
He is a very active member on also founder of openlinksys.info community. Language is not a barrier :)
Galaxy S3 i Tapatalk
ok i'm lost.... i decided to bridge my modem/router and when i do so it doesn't work when openVPN is active.... it does work when it's off (location france) it does work when the modem/router isn't in bridge mode but openVPN activates on the asus router (location whatever the vpn location is) but not if openVPN is active on the asus and tge modem/router is in bridge mode....
any ideas?
