Should I wait? RT-AX86u Pro
Diablo99
I'm confused.
Should I get a Asus RT-AX86u Pro?
I have a RT-AX86u with Latest Merlin.
There a dis-advantages (USB ports) & pro advantages, ( Newer firmware, 2 GHz processor, Guest network ) of the Pro version.
Any suggestions?
D.
I also have an RT-AX86U. I see no reason to replace it with an RT-AX86U Pro or any other model for that matter. What is the problem with your current router that makes you want to change it?
