Silent / Very Quiet NAS recommendations
  • Thread starter Thread starter chowk
  • Start date Start date
C
chowk
Guest
I'm looking to purchase my first NAS and was hoping for some recommendations from the more knowledgable members.
I'm after a NAS that is either silent or very quiet. It'll be used at home for storing media, backup and streaming. I'm not constrained by a budget but ideally I'd like to keep the cost down.
I'd like to get either 2 - 4 bays, starting off with 2 x 1 TB drives (most likely Samsung F1's in a RAID mirror) and possibly upping it to 4 later on.
Is there a big difference in acoustics, going from 2 to 4 bays? If so, I'd definitely consider just getting a 2 bay NAS instead.
Currently I'm considering the Synology DS209+ but I'm really not sure what else is worth considering.
Any suggestions would be much appreciated - thanks!
Generally, the more drives, the more noise, just from drive noise alone.
The DS209+ and other Synology products generally have low noise, as do many others. Use the NAS Charts, filter for the desired features and click "Compare Features" to see noise ratings.
Whatever you do, make sure the drives you select are on the manufacturer's approved list. Very important if you are looking for a blissful relationship with your NAS.
2301 Small (very small) NAS NAS Buying Advice 6
D Quiet NAS / home server NAS Buying Advice 2
