Normally I would agree. But the important thing and that differ from others dualband routers that can run 40MHz (300Mbps) on each band is that these routers can run them simultaneous. 300Mbps at 2,4GHz band (40MHz channel width) and 300Mbps at 5GHz band (40MHz channel width), at the same time. That means 2 streams at 2,4GHz band and 2 streams 5GHz band simultaneous, 4 streams simultaneous. It is that, that make this posseble with 600Mbps.A router with two, two-stream radios is not a four-stream router. It is capable only of a 300 Mbps link rate on each radio when using 40 MHz channel bandwidth and 130 Mbps when using 20 MHz.
So how do you know, if you haven't test it with a 600Mbps card?There are no dual-radio client cards. Three and four-stream radios are not yet available, although three-stream soon will be.
I agree.At that point, a three-stream AP connecting with a three-stream client will show a 450 Mbps link rate when using a 40 MHz channel width.
Yes, I have experience that myself, but I don't think that in this case.Why would a vendor make a claim that can be misleading? They call it "creative" marketing.
I'm curious to hear what you say is required for 4-stream support if not two, two-stream R/F module, is?
Welcome To SNBForums
