SIP Passthrough / NAT helper
Michael Schäfer
is it possible to change the ports used for the SIP passthrough and the NAT helper? It seems to be fixed to 5060 and the only way to get it working on another port is to manually unload nf_conntrack_sip and nf_nat_sip, then modprobe both of them with the ports= parameter. But I can't find a way to get that persistent, i.e. /etc/modules.conf or something like that.
Anyone got a suggestion?
