SixXs - aiccu - reboot - will not work without ipkg install gnutls & libtans1 -force-reinstall
travisnj
I have had problems with aiccu starting after a reboot unless I force resintall gnutls and libtans1
Here is my logcat
ASUSWRT-Merlin RT-AC56U_3.0.0.4 Fri Jul 17 03:16:20 UTC 2015
admin@wifi:/tmp/mnt/sda1/asusware.arm/etc# cd /opt/sbin/
admin@wifi:/tmp/mnt/sda1/asusware.arm/sbin#
admin@wifi:/tmp/mnt/sda1/asusware.arm/sbin# aiccu start
aiccu: can't load library 'libgnutls.so.26'
admin@wifi:/tmp/mnt/sda1/asusware.arm/sbin# aiccu test
admin@wifi:/tmp/mnt/sda1/asusware.arm/sbin# ipkg install gnutls
Package gnutls (2.6.5-1) installed in /opt/ is up to date.
Nothing to be done
Successfully terminated.
admin@wifi:/tmp/mnt/sda1/asusware.arm/sbin# ipkg install gnutls -force-reinstall
Reinstalling gnutls (2.6.5-1) on /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/gnutls_2.6.5-1_arm.ipk
Configuring gnutls
aiccu: can't load library 'libtasn1.so.3'
admin@wifi:/tmp/mnt/sda1/asusware.arm/sbin# ipkg install libtasn1 -force-reinstall
Reinstalling libtasn1 (2.13-1) on /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/libtasn1_2.13-1_arm.ipk
Configuring libtasn1
Tunnel Information for T167569:
POP Id      : uschi02
IPv6 Local  : 2001:4978:f:69c::2/64
IPv6 Remote : 2001:4978:f:69c::1/64
Tunnel Type : 6in4-heartbeat
Adminstate  : enabled
Userstate   : enabled
####### AICCU Quick Connectivity Test
any suggestions would be appreciated
