Skynet Skynet no data to display on AXE16000
msallal
Skynet is not showing any data, it is since more than 72 hours, I already uninstall - install it but still same issue.
the server is working fine but nothing to show
the skynet.log size is 0
also I noticed the Jquery.js did not exist at the root www folder, but it is loaded from JS folder.
it is listed twice in skynet.asp
I want to show that I have some custom firewall rules to enable only Cloudflare IP address to go through my firewall
I appreciate your help on this
As you SSH into the router, Command line - "Firewall", menu option 12, option 1, option 1 - anything events displaying?
Select Menu Option:
[1] --> Unban
[2] --> Ban
[3] --> Malware Blacklist
[4] --> Whitelist
[5] --> Import IP List
[6] --> Deport IP List
[7] --> Save
[8] --> Restart Skynet
[9] --> Temporarily Disable Skynet
[10] --> Update Skynet
[11] --> Settings
[12] --> Debug Options
[13] --> Stats
[14] --> Install Skynet
[15] --> Uninstall
[r] --> Reload Menu
[e] --> Exit Menu
[1-15]: 12
Select Debug Option:
[1] --> Show Log Entries As They Appear
[2] --> Print Debug Info
[3] --> Cleanup Syslog Entries
[4] --> SWAP File Management
[5] --> Backup Skynet Files
[6] --> Restore Skynet Files
[1-6]: 1
Select Watch Option:
[1] --> All
[2] --> IP
[3] --> Port
[1-3]: 1
Select Menu Option:
[1] --> Unban
[2] --> Ban
[4] --> Whitelist
[7] --> Save
[11] --> Settings
[13] --> Stats
[15] --> Uninstall
[r] --> Reload Menu
[e] --> Exit Menu
[1-15]: 12
[1-6]: 1
[1] --> All
[2] --> IP
[3] --> Port
[1-3]: 1
nothing just showing loading, I already banned Facebook and try to hit on Facebook, the ban is activated but not showing on log
I found this on Asus log
Dec 22 19:11:16 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:25:a1:08:00 SRC=xx.xx.xx.xx DST=31.13.88.35 LEN=52 TOS=0x00 PREC=0x00 TTL=128 ID=59870 DF PROTO=TCP SPT=65361 DPT=443 SEQ=321328685 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40103030801010402)
by the way I see the log file modified date is changing, but nothing written to the file
and nothing in the Watching the Syslog also
Some newer models put the syslog.log only on jffs. Check with :
ps ww | grep syslogd
If it says /jffs/syslog.log, you can update Skynet to point to it.
Corerct, it points to /jffs/syslog.log
the issue now, the syslog has both firewall logs and system logs, how can I split the firewall log to be in different file and map the skynet to it.
it is hard to see any system issue when the firewall logs in same file, it uses more than 95% of my logs
Which method of keeping statistics intact - showing periodic inbound and outbound blocks even post reboot. Or is that impossible
