skynet no data to display
andywee
anyone knows what I am getting no data to display in just 2 sections of skynet?
Hi All, my skynet is displaying no data to display for the below 2 items. it's been 3 days since I installed skynet..
Last 10 Unique HTTP(s)
Top 10 HTTP(s) Blocks
| Test Description | | | Result |
Internet-Connectivity | [Passed]
Write Permission | [Passed]
Config File | [Passed]
Firewall-Start Entry | [Passed]
Services-Stop Entry | [Passed]
Service-Event Entry | [Passed]
Profile.add Entry | [Passed]
SWAP File | [Passed]
Cron Jobs | [Passed]
NTP Sync | [Passed]
IPSet Comment Support | [Passed]
Log Level 6 Settings | [Passed]
Duplicate Rules In RAW | [Passed]
IPSets | [Passed]
IPTables Rules | [Passed]
Local WebUI Files | [Passed]
Mounted WebUI Files | [Passed]
MenuTree.js Entry | [Passed]
| Setting | | | Status |
Skynet Auto-Updates | [Enabled]
Malware List Auto-Updates | [Enabled]
Logging | [Enabled]
Filter Traffic | [Enabled]
Unban PrivateIP | [Enabled]
Log Invalid Packets | [Disabled]
Import AiProtect Data | [Enabled]
Secure Mode | [Enabled]
Fast Switch List | [Disabled]
Syslog Location | [Default]
IOT Blocking | [Disabled]
Country Lookup For Stats | [Enabled]
CDN Whitelisting | [Enabled]
Display WebUI | [Enabled]
18/18 Tests Sucessful
sh /jffs/scripts/firewall stats
this also shows NO DATA.
Last 10 Unique HTTP(s) Blocks (Outbound);
| IP Address | | | AlienVault | | | Ban Reason | | | Associated Domains |
Top 10 HTTP(s) Blocks (Outbound);
| Hits | | | IP Address | | | AlienVault | | | Ban Reason | | | Associated Domains |
I had issues with Skynet recently. When I would update the version or force an update to try and resolve the issue, I would get errors with *.js files failing to update.
Try to force an update, watch the output, and see if you get errors that *.js files fail to update.
What I ended up doing to resolve my Skynet issue was to [restore] my router to Factory default with "Initialize all the settings..." [checkbox] checked and to completely wipe/reformat my USB drive.
Then using @L&LD's recommended AMTM script installation order reinstalled my favorite 3rd party scripts. It's working properly now.
Curiously, I had saved to my password manager L@LD's recommended installation order and now cannot find it posted anywhere in this forum. HOPEFULLY he will chime in and offer his UPDATED recommended AMTM script installation order post (so I can update it too).
before i had some AX problems, the charts were working ok. after a hard reset, this problem came. so yeah. it's something that I did or didnt do. probably didnt do since it's less than 14 days of a hard reset.
The block would have to be on ports 80 or 443 in order to count as an http(s) block. You would need to browse a malicious website to trigger it as an outbound block.
