Slingbox problems with Buffalo WZR-HP-G300NH DD-Wrt build 14998
AnthonyC
Hello,
I'm new here, but find this place very informative and helpful. I am looking for some help, as I've recently upgraded from a DGL-4300 to a WZR-HP-G300NH. I like the new router but I can't get my Slingbox to play nice. Has anyone been able to setup a slingbox with the WZR-HP-G300NH? I am running the build 14998 DD-WRT, the new "stock" firmware that comes with the router.
I've set up the port forwarding and enabled uPnp. The internet viewing is not working, although I can see it over LAN. I am pretty sure I have the appropriate ports to forward properly.
I've never had any issues with the slingbox before. I used to have a D-Link DGL-4300 and the setup was less than 5 minutes.
I've also used DD-WRT before, on other devices, so I am familiar with the firmware.
Has anyone successfully set up a slingbox, and how did you do it? I'm about to return this thing, its too bad because I like the router in every other way, but I'm not giving up my slingbox.
