Slow speedtest
thomaspleasance
Hi im currently getting a slow speed test losing 40% of my connection and it looks like im getting high cpu.
Hardware acceleration is enabled and i am connected via ethernet hope you can help.
PS its a PPPoe connection.
PID PPID USER STAT VSZ %MEM %CPU COMMAND
3 2 admin RWN 0 0% 38% [ksoftirqd/0]
2857 1 admin S 1204 1% 27% /usr/sbin/acsd
3091 1 admin S 1548 1% 10% udhcpc -i eth0 -p /var/run/udhcpc0.pid
Asus N66U v3.0.0.4.374_720-gc39b848
it´s possible that you Browser is the bottleneck....
With Firefox I have very slow speed on Speed Tests. With Internetxplorer my speed is like it shouzld be. I think it´s the way the Browser handles the flash player.
Try it with Internetexplorer.
i am using chrome to test my speed. if i connect directly to the ont i get 200/100 speed so its the router even tried ac66u that also has the same problem...
The firmware you're using is known to slow down the RT-N66U and Asus is aware of it. Here's the thread.
http://forums.smallnetbuilder.com/showthread.php?t=12756
