Slow transfer speeds to NAS on my RT-N66U
cdysthe
I often transfer files over wi-fi to a NAS connected to my RT-N66U. I run Ubuntu 13.10 on my laptop and I usually get transfer speeds right around 6 MBps which is decent enough being on wi-fi. I use Samba to for my network Then recently the speed dropped to 1-2 MBps and I had no idea why. I looked at recent updates to my OS and I had just done a kernel upgrade. I then booted the previous version of the kernel and the speed went back up again. I also tried two of the newer mainline kernels, 3.12 and 3.13 from the Ubuntu kernel repo. With 3.12 the speed was still down between 1 - 2 MBps. but with the 3.13 kernel it was up to above 7 MBps, faster than with any other kernel. Why is it such a big difference between kernel versions even between the 3.11 kernels where the initial one that came with 13.10 had the higher upload speed while the latest upgrade 3.11.0.14.15 is slow? I have asked on Ubuntu forums also, but haven't gotten any good answers so I though I would ask here.
Just to be clear. I have tested this so many times now that there's no doubt this has to do with which kernel I am running and not load on my network since I have made sure I am the only one transferring files when I am testing. For now I am running the 3.13 kernel since it works fine and I need the extra speed, but I would like to know why this happens and where I could start looking for the reason.
Maybe they updated the driver for your network card in the update, and the new driver is having problems. See on the manufacturer's website if they have a Linux driver for your wireless adapter.
Also make sure there was no change in MTU size (in case you were previously using jumbo frames).
