SNMPD on GT-AX11000
You can have a read through this post. Different router, but basics are all there
Thanks! Really dumb noob question... but how is opkg enabled?
I try and run it and just get:
-sh: opkg: not found
You need to install entware first vis AMTM (built in general utility script). You will need a USB key. See Merlin's general Wiki pages for details.
Eugh I stupidly installed Asus Download Master to see if it included opkg before you sent that message...
Entware informs me this needs to be removed:
Running pre-install checks
Download Master appears to be installed
/tmp/mnt/Router_Disk/asusware.arm
Entware and Download Master cannot be installed at the same time.
Uninstall Download Master in 'USB Application' first.
Correct above error first before installing Entware
But I don't see any option to remove Download Master in the USB Application view...
