[Solved] Date and Time stability
https://pastebin.com/u2xE4HBb
See logs above. The AC87U router jumped two months ahead, then NTP kicked off and jumped it back to current date and time. Any idea why this is happening? 380.66_4.
The time did not 'jump ahead'. Your router rebooted... or was powered off and on again. Since the router doesn't have RTC battery backup the time/date reverts to 'Jul 31 ...' until the WAN connect stabilizes enough so that NTP can kick in to correct the router's time to the correct time and date.
ok, good to know how that works! That is the scheduled time of the auto weekly reboot.
There is no scheduled reboot unless you set one.
