[SOLVED] Extracting openvpn connection status from the web interface
mad_ady
I'd like to know if there is some sort of API that would allow me to extract openvpn connection status from the web interface? For example, in this image, I'd like to be able to extract the user connected and their IP address: http://imgur.com/GCz61fN.png
I've looked at the page (/www/Advanced_VPNStatus.asp) and there are a lot of markup calls like:
<% nvram_get("wan_proto"); %>
I'd like to know if there is a way to get this data from running code inside the router (I have access to the nvram for example), or if I should scrape the webpage, or maybe the data is accessible some place else in the filesystem (e.g. a log or a temporary file)?
I can get the current connections to both my servers with this:
netstat -tan | egrep "443|1194" | grep ESTABLISHED
But I don't have the IP - Username mapping
Any ideas how I can get that?
You can extract the information needed from the following files:
/etc/openvpn/server1/status respectively from /etc/openvpn/server2/status
Every few seconds, running instances will dump their status info in these files (they exist only if the associated instance actually runs):
/etc/openvpn/client11/status through /etc/openvpn/client5/status
You can also tell an OpenVPN process to dump its data to syslog by sending it a SIGUSR2 signal.
