[solved] mount.cifs from network to a Merlin curlftpfs location
amplatfus
I installed curlftpfs on Merlin and mounted on router location available at /tmp/mnt/ftp.
asus@router:/# curlftpfs domain.com /mnt/ftp -o [email protected]:password,allow_other
asus@router:/# mount
curlftpfs#ftp://domain.com/ on /tmp/mnt/ftp type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
Now I need to mount this as a network folder something like this entered on a network device:
root@linux:/home/guest# mount.cifs //192.168.0.1/domain.com /mnt/ftp -o username=usermerlin,password=password
Retrying with upper case share name
mount error(6): No such device or address
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Could you please help me with a adivice? Is this possible?
Thank you!
Ok, thanks. And could you please show how this can be done?
BR!
In the normal way [USB Application > Network Place(Samba) Share]. If the filesystem doesn't show up there then it probably can't be done.
It doesn't. What I have found in the meantime is that smb.conf must be edited. The solution is to add something to this file in file /jffs/configs/smb.conf.add
Source: https://github.com/RMerl/asuswrt-merlin/wiki/Custom-config-files
What I have found on other site is that I have to add something like into /jffs/configs/smb.conf.add:
[<folder_name>]
path = /home/<user_name>/<folder_name>
valid users = <user_name>
read only = no
Source: https://help.ubuntu.com/community/How to Create a Network Share Via Samba Via CLI (Command-line interface/Linux Terminal) - Uncomplicated, Simple and Brief Way!
I added like this
[ftphand]
path =/tmp/mnt/ftp
valid users = root
read only = no
But now I do not know what to do next.
Thanks!
It's magic, is working. After service restart_ftpsamba I entered:
mount.cifs //192.168.0.1/ftphand/ /mnt/ftphand -o username=user,password=pass
And reading and writing are working both on /mnt/ftphand
PS: I will change the thread title into [solved]
Thank you so much! :)
