Someone has been trying to connect to my vpn over the past 2 months
DanielE
Over the past 2 months, someone from another country has been trying to connect to my vpn. It uses the same ip in every attempt. I do not know if he or she is trying to hack into my network or not.
Nevertheless, I am quite annoyed. What advice would you give to me? Here are parts of the syslog that I found (I have changed his/her ip to 1.2.3.4 for his/her "own good"):
Mar 22 19:32:24 openvpn[779]: 1.2.3.4:59237 TLS: Initial packet from [AF_INET]1.2.3.4:59237, sid=9f4c1f28 aa558e78
Mar 22 19:33:24 openvpn[779]: 1.2.3.4:59237 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Mar 22 19:33:24 openvpn[779]: 1.2.3.4:59237 TLS Error: TLS handshake failed
Mar 22 19:33:24 openvpn[779]: 1.2.3.4:59237 SIGUSR1[soft,tls-error] received, client-instance restarting
Mar 23 23:54:25 openvpn[779]: 1.2.3.4:44562 TLS: Initial packet from [AF_INET]1.2.3.4:44562, sid=9d34c8b7 7f18a760
Mar 23 23:55:25 openvpn[779]: 1.2.3.4:44562 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Mar 23 23:55:25 openvpn[779]: 1.2.3.4:44562 TLS Error: TLS handshake failed
Mar 23 23:55:25 openvpn[779]: 1.2.3.4:44562 SIGUSR1[soft,tls-error] received, client-instance restarting
Apr 10 23:51:38 openvpn[780]: 1.2.3.4:37350 TLS: Initial packet from [AF_INET]1.2.3.4:37350, sid=79c189d9 2d1f2022
Apr 10 23:51:38 openvpn[780]: 1.2.3.4:37350 OpenSSL: error:1408A0C1:SSL routines:ssl3_get_client_hello:no shared cipher
Apr 10 23:51:38 openvpn[780]: 1.2.3.4:37350 TLS_ERROR: BIO read tls_read_plaintext error
Apr 10 23:51:38 openvpn[780]: 1.2.3.4:37350 TLS Error: TLS object -> incoming plaintext read error
Apr 10 23:51:38 openvpn[780]: 1.2.3.4:37350 TLS Error: TLS handshake failed
Apr 10 23:51:38 openvpn[780]: 1.2.3.4:37350 SIGUSR1[soft,tls-error] received, client-instance restarting
Apr 18 23:39:10 openvpn[780]: 1.2.3.4:45248 TLS: Initial packet from [AF_INET]1.2.3.4:45248, sid=7620c24d 0c1eb2e3
Apr 18 23:40:10 openvpn[780]: 1.2.3.4:45248 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Apr 18 23:40:10 openvpn[780]: 1.2.3.4:45248 TLS Error: TLS handshake failed
Apr 18 23:40:10 openvpn[780]: 1.2.3.4:45248 SIGUSR1[soft,tls-error] received, client-instance restarting1.2.3.4
Welcome to the internet.... Any services opened to the internet are picked up by scanners within minutes. Get used to having your doorknob rattled. Make sure you have a STRONG encryption key.
Keep an eye on your logs, password protect any network shares and make sure your router admin password is a strong one too.
Moving OpenVPN to a different port will reduce the amount of noise that gets logged.
