Space low on JFFS storage!!!
sferia82
hi!!!! my router asus ac-86u says:
Your router is running low on free JFFS storage, which might affect its stability.
Review the content of the /jffs directory on your router.
I see this partition as:
/dev/mtdblock9 47.0M 46.4M 612.0K 99% /jffs
But if i enter:
drwxr-xr-x 2 sferia root 0 Apr 15 2020 usericon/
-rw-rw-rw- 1 sferia root 104.0K Oct 15 18:49 syslog.log-1
-rw-rw-rw- 1 sferia root 10.4K Oct 15 18:49 syslog.log
drwxrwxrwx 2 sferia root 0 Oct 15 12:03 signature/
drwxr-xr-x 2 sferia root 0 May 5 2018 scripts/
drwx------ 2 sferia root 0 Apr 15 2020 openvpn/
-rw-rw-rw- 1 sferia root 0 Jan 1 1970 nvram_war
drwxrwxrwx 2 sferia root 0 Oct 15 18:31 nvram/
-rw-r--r-- 1 sferia root 6.2K Oct 15 18:40 nmp_cl_json.js
drwxr-xr-x 2 sferia root 0 May 5 2018 configs/
-rw-r--r-- 1 sferia root 74 May 16 09:10 cfg.json
-rw-rw-rw- 1 sferia root 2.2K Oct 14 15:09 cert.tgz
drwxr-xr-x 2 sferia root 0 May 5 2018 addons/
drwx------ 3 tor tor 0 Apr 15 2020 .tordb/
drwxrwxrwx 8 sferia root 0 Jul 18 10:27 .sys/
drw------- 2 sferia root 0 Feb 22 2020 .le/
drw------- 2 sferia root 0 May 5 2018 .cert/
drwxr-xr-x 20 sferia root 1.8K Aug 14 22:39 ../
drwxr-xr-x 14 sferia root 0 Oct 15 18:49 ./
Where is the other space until 47M?
If i format jffs patition at next boot i missed configuration of vpn? its possible dont miss it?
thanks.
i find this:
sferia@RT-AC86U-8368:/jffs/.sys# du -sh
126.5M .
sferia@RT-AC86U-8368:/jffs/.sys# du -sh *
89.9M AiProtectionMonitor
23.6M TrafficAnalyzer
512 WBL
4.0M WebHistory
0 cfg_mnt
8.9M nc
Coincidentally, today my RT-AC86U gave the same warning that JFFS was nearly full - I also have nearly 60Mb of traffic analyzer database files - I'm going to see how to disable it or clear the database
Did the same thing recently and now my JFFs stays around 15mb used.
now i don't know how to disable traffic analyzer
just clear it via Traffic analyzer --> Statistic tab and press the delete button when in "devices and "apps" vie. My JFFS went from 2.5MB free to 27.1MB
@RT-AC86U:/tmp/home/root# df -h /jffs
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock9 47.0M 44.7M 2.3M 95% /jffs
/dev/mtdblock9 47.0M 19.9M 27.1M 42% /jffs
