spdMerlin spdMerlin - Automated speedtests with graphs
Jack Yaz
Part of the Furniture
v3.6.1
Updated 2020-05-25
Run automated speedtests for your Internet on your router with graphs available on the Addons page of the WebUI.
This script began as a user-friendly installer for a personal project developed by @JGrana
spdMerlin is free to use under the GNU General Public License version 3 (GPL 3.0).
spdMerlin uses SpeedTest CLI
If the speeds from this utility are significantly lower than those you see from the desktop app/browser test, the limiting factor will be your router's CPU. That being said, there is probably room for improvement/optimisation by the Ookla team in the CLI binary itself. Please direct feedback about speed issues to Ookla via the above link. There is nothing that I can do about them.
spdMerlin includes the required licenses, which must be accepted on first run of Speedtest CLI.
A swap file is required to ensure smooth operation of the script.
The speedtest is scheduled to run at 12 past and 42 past the hour, every hour, by default
This project is hosted on GitHub
Love the script and want to support future development? Any and all donations gratefully received!
PayPal donation
Buy me a coffee
Supported firmware versions
You must be running firmware Merlin 384.15/384.13_4 or Fork 43E5 (or later) Asuswrt-Merlin
Installation
Using your preferred SSH client/terminal, copy and paste the following command, then press Enter:
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/spdMerlin/master/spdmerlin.sh" -o "/jffs/scripts/spdmerlin" && chmod 0755 /jffs/scripts/spdmerlin && /jffs/scripts/spdmerlin install
Usage
To launch the spdMerlin menu after installation, use:
spdmerlin
If this does not work, you will need to use the full path:
Updating
Launch spdmerlin and select option u
Screenshots:
You're teasing us! :D
But the name already sounds great! 'spdMerlin'. :)
Sorry SPD?
Looks like RT-AC68U is not supported. :(
But the graphs look great in the GUI (not populated right now, of course)! :) :) :)
ASUSWRT-Merlin RT-AC68U 384.10-0 Sun Mar 24 21:35:16 UTC 2019
admin@RT-AC68U:/tmp/home/root# /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/spdMerlin/mas
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 19527  100 19527    0     0  41109      0 --:--:-- --:--:-- --:--:-- 45201
spdMerlin: Welcome to spdMerlin v1.0.0, a script by JackYaz
spdMerlin: Checking your router meets the requirements for spdMerlin
Installing python (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python_2.7.15-5_armv7-2.6.ipk
Installing python-base (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-base_2.7.15-5_armv7-2.6.ipk
Installing libffi (3.2.1-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libffi_3.2.1-3_armv7-2.6.ipk
Installing libbz2 (1.0.6-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libbz2_1.0.6-5_armv7-2.6.ipk
Configuring python-base.
Configuring libffi.
Collected errors:
 * opkg_download: Failed to download http://bin.entware.net/armv7sf-k2.6/libbz2_1.0.6-5_armv7-2.6.ipk, wget returned 8.
 * opkg_install_pkg: Failed to download libbz2. Perhaps you need to run 'opkg update'?
 * opkg_install_cmd: Cannot install package python.
Package rrdtool (1.2.30-3a) installed in root is up to date.
spdMerlin: Starting speedtest now...
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
Traceback (most recent call last):
  File "/jffs/scripts/spdcli.py", line 20, in <module>
    import csv
ImportError: No module named csv
spdMerlin: Finished speedtest
Configuring libffi.
Collected errors:
    import csv
Try opkg update?
If not, this ipkg looks right: http://bin.entware.net/armv7sf-k2.6/libbz2_1.0.6-5a_armv7-2.6.ipk
curl -fsL --retry 3 "http://bin.entware.net/armv7sf-k2.6/libbz2_1.0.6-5a_armv7-2.6.ipk" -o /tmp/libbz.ipk
opkg install /tmp/libbz.ipk
I did try opkg update:
admin@RT-AC68U:/tmp/home/root# opkg update
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
I'm not quite sure what to do with the link you provided? I can't seem to see the page, no matter how many times I click it.
See my edit, I added a code sample. Once done, try re-running spdMerlin's install routine
EDIT: This appears to be an Entware repo problem with a mismatched dependency, rather than the script. Not sure what to do with that information though...
EDIT2: https://github.com/Entware/Entware/issues/263
Thanks, the ipkg worked to install that package, but now this is showing.
    import csv
Press enter to continue...
    import csv
Did you re-run the install command for spdMerlin?
Should I uninstall it first? I ran 'u' and 'uf'. :oops:
I'll re-run the actual installer. Thank you!
No don't uninstall as that'll wipe the package you just installed. Hopefully the installer will work
(equally opkg install python)
EDIT: If it doesn't, we get to start trying to find which packages got installed on HND/ARMv8 that don't get installed on ARMv7
The only error seems to be an SSL certificate error now.
100 19527  100 19527    0     0  89986      0 --:--:-- --:--:-- --:--:--  100k
Installing libtirpc (1.1.4-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libtirpc_1.1.4-1_armv7-2.6.ipk
Installing python-light (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-light_2.7.15-5_armv7-2.6.ipk
Installing python-ctypes (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-ctypes_2.7.15-5_armv7-2.6.ipk
Installing python-pydoc (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-pydoc_2.7.15-5_armv7-2.6.ipk
Installing python-multiprocessing (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-multiprocessing_2.7.15-5_armv7-2.6.ipk
Installing python-codecs (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-codecs_2.7.15-5_armv7-2.6.ipk
Installing libsqlite3 (3260000-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libsqlite3_3260000-3_armv7-2.6.ipk
Installing python-sqlite3 (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-sqlite3_2.7.15-5_armv7-2.6.ipk
Installing python-logging (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-logging_2.7.15-5_armv7-2.6.ipk
Installing libgdbm (1.11-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libgdbm_1.11-1_armv7-2.6.ipk
Installing python-gdbm (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-gdbm_2.7.15-5_armv7-2.6.ipk
Installing python-email (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-email_2.7.15-5_armv7-2.6.ipk
Installing python-distutils (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-distutils_2.7.15-5_armv7-2.6.ipk
Installing libexpat (2.2.6-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libexpat_2.2.6-1_armv7-2.6.ipk
Installing python-xml (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-xml_2.7.15-5_armv7-2.6.ipk
Installing python-compiler (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-compiler_2.7.15-5_armv7-2.6.ipk
Installing libxml2 (2.9.9-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libxml2_2.9.9-1_armv7-2.6.ipk
Installing libdb47 (4.7.25.4.NC-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libdb47_4.7.25.4.NC-5_armv7-2.6.ipk
Installing python-db (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-db_2.7.15-5_armv7-2.6.ipk
Installing python-openssl (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-openssl_2.7.15-5_armv7-2.6.ipk
Installing python-decimal (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-decimal_2.7.15-5_armv7-2.6.ipk
Installing python-unittest (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-unittest_2.7.15-5_armv7-2.6.ipk
Installing libncursesw (6.1-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libncursesw_6.1-3_armv7-2.6.ipk
Installing libncurses (6.1-3) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libncurses_6.1-3_armv7-2.6.ipk
Installing python-ncurses (2.7.15-5) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/python-ncurses_2.7.15-5_armv7-2.6.ipk
Configuring libtirpc.
Configuring python-light.
Configuring python-codecs.
Configuring libxml2.
Configuring libdb47.
Configuring python-db.
Configuring python-decimal.
Configuring python-distutils.
Configuring python-pydoc.
Configuring python-ctypes.
Configuring python-multiprocessing.
Configuring libsqlite3.
Configuring python-sqlite3.
Configuring python-logging.
Configuring libgdbm.
Configuring python-gdbm.
Configuring python-email.
Configuring libexpat.
Configuring python-xml.
Configuring python-compiler.
Configuring python-openssl.
Configuring python-unittest.
Configuring libncursesw.
Configuring libncurses.
Configuring python-ncurses.
Configuring python.
Cannot retrieve speedtest configuration
ERROR: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:726)>
Configuring python.
Looks like the --secure flag not playing nice. Not sure what'd cause that :/
Would any of the other scripts be interfering? Like Stubby or Skynet? Maybe an AiProtection interaction as it is enabled too (sorry, just guessing)?
