spdMerlin spdMerlin v4.4.19 [2026-Apr-12] - Internet Speedtest and Monitoring Tool for AsusWRT Merlin
Are both of these files still valid? I suspect the script could be erroring out if one is not found. I thought all the Entware modules moved exclusively to amtm.
I believe . /jffs/addons/amtm/mount-entware.mod is still valid:
not sure what about: . /jffs/addons/diversion/mount-entware.div though.
Even if it's not valid though, the lines following in his post-mount are running as expected (such as tailmon)
cat /jffs/scripts/post-mount
#!/bin/sh
swapon /tmp/mnt/USB_120GB/myswap.swp # Added by amtm
. /jffs/addons/amtm/mount-entware.mod # Added by amtm
. /jffs/addons/diversion/mount-entware.div # Added by amtm
(sleep 30 && /jffs/scripts/tailmon.sh -screen) & # Added by tailmon
[ -x "${1}/entware/bin/opkg" ] && [ -x /jffs/scripts/spdmerlin ] && /jffs/scripts/spdmerlin startup "$@" & # spdMerlin
AsusAdmin@RT-AX88U_Pro-0998:/tmp/home/root#
And here is the systemlog confirming that part:
Jan  1 00:02:03 Entware: Starting Entware services on /tmp/mnt/USB_120GB
Jan  1 00:02:03 AsusAdmin: Started tailscaled from /jffs/scripts/post-mount.
I've gone ahead and did a very quick spdMerlin code review. I found out -to my surprise- that force update, and update processes DO NOT check for the existence of the startup command line the script needs at router's boot up, or to be more specific, after a USB disk is mounted.
That's the wrong assessment. You're not reading the code correctly, or you're not doing the proper analysis to understand the execution flow. The check is always done after the add-on update (or force update) has completed.
Is that really from tailmon, or is it the Entware startup script running?
@alan6854321 should just run:
/jffs/scripts/post-mount /tmp/mnt/dummy
And see if it complains.
That's a good point, I assumed it came from tailmon but it could be just the entware service.
Let's see what alan says with the test
Alan says "Yahoo - it works!"
This confirms the problem was solved by removing:
From the post-mount script.
Seems like maybe diversion left some remnants behind? Causing post-mount to fail to run the lines following.
Which means alan was likely having issues with both spdmerlin as well as tailmon.
A minor surprise, TAILMON sent me an Email, it's never done that before....
WARNING: Router Has Unexpectedly Restarted
Date/Time: Nov 13 2025 15:51:08
WARNING: TAILMON has detected that the router may have rebooted or was restarted. TAILMON.
has reset the service, and reestablished a connection to your Tailnet. Please investigate if this
behavior continues to persist.
Sent by the "tailmon.sh" script.
From the "RT-AX88U" router.
2025-Nov-13 Thu 03:51:08 PM GMT
Happy you found a solution! And it required no code changes!
I'd like to know more about why that was left behind in your post-mount though if it's no longer valid.
We may need to poke @thelonelycoder for that one though.
I just noticed your comment, but I've never run diversion on any of my routers (I use PiHole)
So how did that get there?
Interesting, then I'm not sure I'm qualified to answer that one.
Hopefully thelonelycoder has more of an idea where it comes from.
What would happen if I just ran the post-mount script in a terminal, would it cause problems?
Yeah, it might cause a lot of problems.
In general, running the "post-mount" script a second time in the same router boot cycle, will run second instances of each script called from there, which probably might cause various problems for already running scripts. It also might cause errors when trying to execute commands that shouldn't be executed twice in the same boot cycle.
This is the general case though. Most of the scripts in this community already deal with these problems with lock files and other proper means.
So FYI, no, running post-mount script a second time is totally a bad idea.
If the router uptime is less than 10 minutes and TAILMON was started during that time, it assumes the router was just restarted. It was added by popular demand as a way to detect a possibly unplanned reboot to make sure things were still working with Tailscale. Over time, it's been a great notification on those rare times my router has spontaneously rebooted for no reason so I can dig into it further. Thinking about adding this feature to RTRMON as well. ;)
(Sorry for the off-topic post guys! :) )
Release Notes for spdMerlin v4.4.16 production version now available
[2025-Nov-16]
1) FIXED: Modified code to make sure we get the correct parameters when changing settings from the WebUI.
2) Miscellaneous code improvements.
The fork from @Jack Yaz's spdMerlin add-on is now hosted on the AMTM-OSR GitHub repo:
Yes, thing is I only saw this message when I removed the
"/jffs/addons/diversion/mount-entware.div # Added by amtm"
line from the post-mount script. Despite many reboots trying to find my problem with the spdMerlin WebUI.
(You might need to read back through this thread to understand what I'm talking about)
That's exactly the reason why.
It's not a problem with his script.
It was a problem with your post-mount.
Once that problem was solved, then his script could send the notification as intended.
Yes, but the weird thing is that Tailscale was starting up and running quite happily while the "mount-entware.div" line was still present in post-mount.
Or maybe - tailscale starts up without needing TAILMON.
I have been assuming that the tailscale process is started by TAILMON.
That is exactly what was happening. As Dave pointed out, it wasn't tailmon that started tailscale.
It was entware (the 3rd line in your post mount) that was starting tailscale.
You are absolutely right. TAILMON will sit in the background to ensure the service is up, and if configured, will try to restart the services if they are down. But @alan6854321, this is only after-the-fact after the router has rebooted and the entware services were started as @ExtremeFiretop refers to above.
There's something odd happening with my spdmerlin, and I can't figure out what 😅
Whenever I run a manual Speedtest (auto server), it uses correctly my upload speed (around 400mbps).
Whenever it runs unattended via Cronjob, it's capped around 150mbps. Every single time . Auto server also.
However, if I run /jffs/scripts/spdmerlin generate in terminal (the Cron command), the upload goes up to those 400mbps.
Download speed is correctly tested in both scenarios (around 1gbps)
Any ideas why?
