SpeedTest Typical Results?
BostonDan
Just curious, what type of real-world speeds are people getting when using Speedtest.net.
I have Gibabit Internet, Netgear Rax70 and a standard laptop(Dell XPS-7390) about 10 feet away?
When speedtest.net is run, I’m getting around 450MB download speeds. Is this normal?
When testing WAN speed, test with an Ethernet cable. Otherwise, you are highly likely to be limited by your wifi rather than your Internet connection.
and 160-MHz to -> ON, 4800 MBit/s over 5GHz, but just theoritical because of no MIMO-Streams (just two MIMO, results in 2402 MBit/s in a Test).
Over 80 MHz Channels -> 1.2 GBit/s with two MIMO and Over 2,4 GHz upto 574 MBit/s.
All over Short Range, long Range is arround 40-80 MBit/s on 5 GHz and 20 MBit/s on the 2.4 GHz in a Test.
German Source: https://www.pcwelt.de/article/1205553/test-netgear-nighthawk-rax70-wi-fi-6-wlan-router.html
