SSHdaemon - WAN-access - using iptables - doesn't work, why not?
Martin - SNBuser
Hi all,
Why doesn't this give me access to SSH from the public IP (WAN-side of the Asus router) ? I have enabled SSH on the LAN-side of the router (Administration / System / SSH Daemon / "Enable SSH" = "LAN only", hence I'm assuming an SSHD-server is running, also because I can SSH to the router from 192.168.1.XXX)?
# iptables -F
# iptables -X
# iptables -P FORWARD ACCEPT
# iptables -L -v
Chain INPUT (policy ACCEPT 12 packets, 2992 bytes)
pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy ACCEPT 12 packets, 2292 bytes)
Chain OUTPUT (policy ACCEPT 8 packets, 2896 bytes)
Everything should be ACCEPT'ed as far as I can see... Also, I don't see any SSHD process running:
# ps | grep -i ssh
9082 wrt54g    1380 S    grep -i ssh
I would like to understand this, so I can setup my fwknop-rules (this is like port-knocking, so I can dynamically turn on access to port 22 whenever I need it and so it's seen as "filtered" 99% of the time, where I don't need SSHD on the router)... Or do I need to maybe install an extra SSHD-server, e.g:
# opkg list | grep -i ssh | grep -i serve
dropbear - 2016.73-1 - A small SSH2 server/client designed for small memory environments.
openssh-server - 7.3p1-1 - OpenSSH server.
? Please advice!
The sshd daemon is called dropbear, not ssh.
Setting it to LAN only won't bind it to the WAN interface. You need to set it to LAN+WAN for the daemon to listen to both the LAN and the WAN interfaces.
Thanks! But I don't want LAN+WAN because that makes port 22 open and exposed to the internet, the whole time - open for attackers from Asia, Russia and wherever they are on the globe...
I wish to make dropbear/sshd work with "fwknop", e.g. this daemon keeps port 22 open for e.g. 30 seconds after receiving an SPA-packet. So 95%-99% of the time, port 22 is "filtered". And then I send an SPA packet, when I need to login. Within these 30 seconds (or whatever timeframe) I need to SSH from the WAN-side before fwknopd automatically closes the port again, on the WAN-side... Questions:
1) Is it impossible to get access to dropbear from the WAN-side, without turning on "LAN+WAN" in the GUI (normally I really really do not wish to expose any open ports/services on the internet, making my router vulnerable to attackers/hackers, so I'm seeking a way to access dropbear from eth0-interface - I prefer all my ports "filtered" or DROP'ed from the internet but LAN+WAN would make me visible)...
2) Is it really impossible to make a rule in IPTABLES (maybe either something iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 22 -j MySSHrule or maybe something filter/INPUT or maybe ebtables: INPUT or BROUTING) so dropbear thinks a connection from eth0 is really from - maybe br0 ? Isn't that a PREROUTING-rule or something?
I'll post my steps to the forum, if I make it work (for future reference) - if anyone wants a similar solution with fwknop...
Turn it on for LAN + WAN, then simply delete the rule that opens port 22 in the INPUT chain, and replace it by your desired rules than handle port knocking through a firewall-start script.
Oh, it sounds so simple - stupid of me not to think about it like that... I'm currently not near my router, but tonight I'll test it and I think this sounds so simple that I really suspect it to work without any problems...
In case anyone else wants a similar solution, I think I might as well just throw a reference to how how I've setup the fwknopd config files: https://sourceforge.net/p/fwknop/mailman/fwknop-discuss/?viewmonth=201609
I believe (am 95% sure) everything with SSH and fwknopd will work very soon, now, as I don't see why your suggestion should not work... Thank you very much, RMerlin...
