Still running 3.0.0.3.108
Chippy_boy
I haven't messed with my router for ages, having been working on other stuff. I note I am still on 3.0.0.3.108 - which I guess is like ancient these days.
That said, looking at the stats, it's been up for 173 days and counting, so it's EXTREMELY stable. (The last downtime was probably a power cut.)
Should I update to latest firmware, or does the "if it aint broke, don't fix it" rule apply? Am I missing out on anything that I really ought to have - like security fixes or killer features?
I'd appreciate any thoughts.
Cheers
Chippy
It is like yourself wrote : if you have no problems / issues with your old f/w
do not upgrade BUT if you want new functions it's time to upgrade.
Cheers
Chippy
Beside the additional features, maybe some bugfixing plus by sure some security fixes, are worth upgrading. :rolleyes:
Coming form that old version it would be highly recommened to do a factory rest (clear NVRAM) after upgrading to get all default values - especially the hidden ones - from the new firmware. :eek:
This demands then a re-entering of all settings to bring things back to work.
With kind regards
Joe :cool:
PS.: As you can see from my footer, I am the oppostite of you: Always looking for the latest and greatest updates... ;)
