I use Padavan´s Firmware an can see my connections. Everytime I check my Connections I see:
udp connection:
Source 10.104.128.1 src port 67 Destination 255.255.255.255 dst port 68
I read about the connection to port 68 is related to dhcp.
But I have no Device with this IP?
my internal adresses are 192.168.1.x
I have the Asus Router behind a Motorola Surfboard Modem. Is it possible that it has something to do with my Motorola Modem? If I ping this IP the ping jumps up and down - 8 ms the lowest 33 ms the highest...
udp connection:
