Strange log RT-AC87U FW 380.7378
VANT
I have observed strange log today. Can anybody explain this ?
Jun 15 11:30:21 kernel: ------------[ cut here ]------------
Jun 15 11:30:21 kernel: WARNING: at net/sched/sch_generic.c:261 dev_watchdog+0x26c/0x28c()
Jun 15 11:30:21 kernel: module:  wl    bf038000    3938054
Jun 15 11:30:21 kernel: module:  ebtable_broute    bf032000    873
Jun 15 11:30:21 kernel: module:  ebtable_filter    bf007000    1061
Jun 15 11:30:21 kernel: module:  ebt_mark    bf423000    814
Jun 15 11:30:21 kernel: module:  ebtable_nat    bf027000    1056
Jun 15 11:30:21 kernel: module:  ebtables    bf01c000    15643
Jun 15 11:30:21 kernel: module:  ct_notification    bf7b4000    1684
Jun 15 11:30:21 kernel: module:  bw_forward    bf794000    93980
Jun 15 11:30:21 kernel: module:  IDP    bf708000    529190
Jun 15 11:30:21 kernel: module:  nf_nat_sip    bf701000    5031
Jun 15 11:30:21 kernel: module:  nf_conntrack_sip    bf6f8000    15713
Jun 15 11:30:21 kernel: module:  nf_nat_h323    bf6f1000    4761
Jun 15 11:30:21 kernel: module:  nf_conntrack_h323    bf6e3000    33807
Jun 15 11:30:21 kernel: module:  nf_nat_rtsp    bf6dd000    3202
Jun 15 11:30:21 kernel: module:  nf_conntrack_rtsp    bf6d7000    4067
Jun 15 11:30:21 kernel: module:  nf_nat_ftp    bf6d1000    1144
Jun 15 11:30:21 kernel: module:  nf_conntrack_ftp    bf6ca000    4909
Jun 15 11:30:21 kernel: module:  ip6table_mangle    bf6c4000    934
Jun 15 11:30:21 kernel: module:  cdc_mbim    bf6be000    3129
Jun 15 11:30:21 kernel: module:  qmi_wwan    bf6b7000    5780
Jun 15 11:30:21 kernel: module:  cdc_wdm    bf6b0000    7252
Jun 15 11:30:21 kernel: module:  cdc_ncm    bf6a8000    8750
Jun 15 11:30:21 kernel: module:  rndis_host    bf6a1000    4936
Jun 15 11:30:21 kernel: module:  cdc_ether    bf69b000    3187
Jun 15 11:30:21 kernel: module:  asix    bf693000    10832
Jun 15 11:30:21 kernel: module:  usbnet    bf68a000    11161
Jun 15 11:30:21 kernel: module:  mii    bf684000    3367
Jun 15 11:30:21 kernel: module:  usblp    bf67c000    10321
Jun 15 11:30:21 kernel: module:  ohci_hcd    bf672000    17918
Jun 15 11:30:21 kernel: module:  ehci_hcd    bf665000    31565
Jun 15 11:30:21 kernel: module:  xhci_hcd    bf652000    50352
Jun 15 11:30:21 kernel: module:  thfsplus    bf636000    81793
Jun 15 11:30:21 kernel: module:  tntfs    bf5ba000    454497
Jun 15 11:30:21 kernel: module:  tfat    bf581000    188546
Jun 15 11:30:21 kernel: module:  ext2    bf56d000    52776
Jun 15 11:30:21 kernel: module:  ext4    bf52c000    221674
Jun 15 11:30:21 kernel: module:  jbd2    bf519000    48993
Jun 15 11:30:21 kernel: module:  crc16    bf513000    1007
Jun 15 11:30:21 kernel: module:  ext3    bf4f1000    106409
Jun 15 11:30:21 kernel: module:  jbd    bf4e0000    42367
Jun 15 11:30:21 kernel: module:  mbcache    bf4d9000    4599
Jun 15 11:30:21 kernel: module:  usb_storage    bf4ca000    34110
Jun 15 11:30:21 kernel: module:  sg    bf4bf000    19855
Jun 15 11:30:21 kernel: module:  sd_mod    bf4b3000    21983
Jun 15 11:30:21 kernel: module:  scsi_wait_scan    bf4ad000    416
Jun 15 11:30:21 kernel: module:  scsi_mod    bf488000    108738
Jun 15 11:30:21 kernel: module:  usbcore    bf465000    101810
Jun 15 11:30:21 kernel: module:  ip6t_LOG    bf45e000    4494
Jun 15 11:30:21 kernel: module:  ip6table_filter    bf458000    750
Jun 15 11:30:21 kernel: module:  jffs2    bf43a000    91274
Jun 15 11:30:21 kernel: module:  zlib_deflate    bf430000    19489
Jun 15 11:30:21 kernel: module:  igs    bf02a000    11887
Jun 15 11:30:21 kernel: module:  emf    bf021000    15157
Jun 15 11:30:21 kernel: module:  et    bf00a000    61445
Jun 15 11:30:21 kernel: module:  ctf    bf000000    20367
Jun 15 11:30:21 kernel: Modules linked in: wl(P) ebtable_broute ebtable_filter ebt_mark ebtable_nat ebtables ct_notification bw_forward(P) IDP(P) nf_nat_sip nf_conntrack_sip nf_nat_h323 nf_conntrack_h323 nf_nat_rtsp nf_conntrack_rtsp nf_nat_ftp nf_conntrack_ftp ip6table_mangle cdc_mbim qmi_wwan cdc_wdm cdc_ncm rndis_host cdc_ether asix usbnet mii usblp ohci_hcd ehci_hcd xhci_hcd thfsplus tntfs(P) tfat(P) ext2 ext4 jbd2 crc16 ext3 jbd mbcache usb_storage sg sd_mod scsi_wait_scan scsi_mod usbcore ip6t_LOG
Jun 15 11:30:21 kernel: [<c0043ff8>] (unwind_backtrace+0x0/0xf8) from [<c0061d80>] (warn_slowpath_common+0x4c/0x64)
Jun 15 11:30:21 kernel: [<c0061d80>] (warn_slowpath_common+0x4c/0x64) from [<c0061e2c>] (warn_slowpath_fmt+0x30/0x40)
Jun 15 11:30:21 kernel: [<c0061e2c>] (warn_slowpath_fmt+0x30/0x40) from [<c020c154>] (dev_watchdog+0x26c/0x28c)
Jun 15 11:30:21 kernel: [<c020c154>] (dev_watchdog+0x26c/0x28c) from [<c006ce2c>] (run_timer_softirq+0x134/0x250)
Jun 15 11:30:21 kernel: [<c006ce2c>] (run_timer_softirq+0x134/0x250) from [<c0383308>] (__do_softirq+0xac/0x148)
Jun 15 11:30:21 kernel: [<c0383308>] (__do_softirq+0xac/0x148) from [<c00678ec>] (irq_exit+0x58/0x6c)
Jun 15 11:30:21 kernel: [<c00678ec>] (irq_exit+0x58/0x6c) from [<c003d204>] (do_local_timer+0x54/0x70)
Jun 15 11:30:21 kernel: [<c003d204>] (do_local_timer+0x54/0x70) from [<c0382a88>] (__irq_svc+0x48/0xe8)
Jun 15 11:30:21 kernel: Exception stack(0xcf843f98 to 0xcf843fe0)
Jun 15 11:30:21 kernel: 3f80:                                                       00000002 cf9d1800
Jun 15 11:30:22 kernel: 3fa0: cf843fe0 00000000 cf842000 c03e00a8 c03c8b80 c03e0214 00000000 413fc090
Jun 15 11:30:22 kernel: 3fc0: 0000001f 00000000 00000000 cf843fe0 c003ebe4 c003ebe8 60000013 ffffffff
Jun 15 11:30:22 kernel: [<c0382a88>] (__irq_svc+0x48/0xe8) from [<c003ebe8>] (default_idle+0x24/0x28)
Jun 15 11:30:22 kernel: [<c003ebe8>] (default_idle+0x24/0x28) from [<c003ed88>] (cpu_idle+0x70/0xa4)
Jun 15 11:30:22 kernel: [<c003ed88>] (cpu_idle+0x70/0xa4) from [<00008084>] (0x8084)
Jun 15 11:30:22 kernel: ---[ end trace a407cb025b26249e ]---
G Traffic monitor log incomplete ASUS AC Routers & Adapters (Wi-Fi 5) 3
