Hello,
I've an Asus RT-AC68U with latest Merlin 384.6
For connecting to the Internet, I'm using an Huawei E3372s connected via HiLink mode.
Detail:
Everything works smoothly until connection drops due to the kernel error reported below.
To make things working again, I've to reboot the router.
Please note that I've just made a clean installation of everything.
Kernel error log:
Full log HERE.
Detail:
Kernel error log:
Aug 22 17:15:11 kernel: ------------[ cut here ]------------
Aug 22 17:15:11 kernel: WARNING: at net/sched/sch_generic.c:261 dev_watchdog+0x26c/0x28c()
Aug 22 17:15:11 kernel: NETDEV WATCHDOG: eth3 (cdc_ether): transmit queue 0 timed out
Aug 22 17:15:11 kernel: module: tun bf4b3000 12274
Aug 22 17:15:11 kernel: module: tdts_udbfw bf4d4000 26092
Aug 22 17:15:11 kernel: module: tdts_udb bf43d000 180247
Aug 22 17:15:11 kernel: module: tdts bf773000 416313
Aug 22 17:15:11 kernel: module: nf_nat_sip bf76c000 5031
Aug 22 17:15:11 kernel: module: nf_conntrack_sip bf763000 15713
Aug 22 17:15:11 kernel: module: nf_nat_h323 bf75c000 4761
Aug 22 17:15:11 kernel: module: nf_conntrack_h323 bf74e000 33807
Aug 22 17:15:11 kernel: module: nf_nat_rtsp bf748000 3202
Aug 22 17:15:11 kernel: module: nf_conntrack_rtsp bf742000 4067
Aug 22 17:15:11 kernel: module: nf_nat_ftp bf73c000 1144
Aug 22 17:15:11 kernel: module: nf_conntrack_ftp bf735000 4909
Aug 22 17:15:11 kernel: module: ip6table_mangle bf72f000 934
Aug 22 17:15:11 kernel: module: usblp bf727000 10321
Aug 22 17:15:11 kernel: module: thfsplus bf70b000 81793
Aug 22 17:15:11 kernel: module: tntfs bf68f000 454497
Aug 22 17:15:11 kernel: module: tfat bf656000 188546
Aug 22 17:15:11 kernel: module: ext2 bf642000 52776
Aug 22 17:15:11 kernel: module: ext4 bf601000 221674
Aug 22 17:15:11 kernel: module: jbd2 bf5ee000 48993
Aug 22 17:15:11 kernel: module: crc16 bf5e8000 1007
Aug 22 17:15:11 kernel: module: ext3 bf5c6000 106409
Aug 22 17:15:11 kernel: module: jbd bf5b5000 42367
Aug 22 17:15:11 kernel: module: mbcache bf5ae000 4599
Aug 22 17:15:11 kernel: module: usb_storage bf59f000 34290
Aug 22 17:15:11 kernel: module: sg bf594000 19855
Aug 22 17:15:11 kernel: module: sd_mod bf588000 21983
Aug 22 17:15:11 kernel: module: scsi_wait_scan bf582000 416
Aug 22 17:15:11 kernel: module: scsi_mod bf55d000 108738
Aug 22 17:15:11 kernel: module: cdc_mbim bf557000 3137
Aug 22 17:15:11 kernel: module: qmi_wwan bf550000 5816
Aug 22 17:15:11 kernel: module: cdc_wdm bf549000 7252
Aug 22 17:15:11 kernel: module: cdc_ncm bf541000 8762
Aug 22 17:15:11 kernel: module: rndis_host bf53a000 5256
Aug 22 17:15:11 kernel: module: cdc_ether bf534000 4036
Aug 22 17:15:11 kernel: module: asix bf52c000 10856
Aug 22 17:15:11 kernel: module: cdc_acm bf523000 12614
Aug 22 17:15:11 kernel: module: usbnet bf51a000 11900
Aug 22 17:15:11 kernel: module: mii bf514000 3367
Aug 22 17:15:11 kernel: module: ip6t_LOG bf50d000 4494
Aug 22 17:15:11 kernel: module: ip6table_filter bf507000 750
Aug 22 17:15:11 kernel: module: ohci_hcd bf4fd000 17926
Aug 22 17:15:11 kernel: module: ehci_hcd bf4ef000 32382
Aug 22 17:15:11 kernel: module: xhci_hcd bf4dc000 51132
Aug 22 17:15:11 kernel: module: usbcore bf4b8000 102572
Aug 22 17:15:11 kernel: module: jffs2 bf49a000 91274
Aug 22 17:15:11 kernel: module: zlib_deflate bf490000 19489
Aug 22 17:15:11 kernel: module: nf_nat_pptp bf48a000 1602
Aug 22 17:15:11 kernel: module: nf_conntrack_pptp bf484000 3355
Aug 22 17:15:11 kernel: module: nf_nat_proto_gre bf47e000 887
Aug 22 17:15:11 kernel: module: nf_conntrack_proto_gre bf478000 3296
Aug 22 17:15:11 kernel: module: wl bf03a000 4196356
Aug 22 17:15:11 kernel: module: dpsta bf033000 5900
Aug 22 17:15:11 kernel: module: et bf01c000 64624
Aug 22 17:15:11 kernel: module: igs bf014000 11887
Aug 22 17:15:11 kernel: module: emf bf00b000 15225
Aug 22 17:15:11 kernel: module: ctf bf000000 20875
Aug 22 17:15:11 kernel: Modules linked in: tun tdts_udbfw tdts_udb(P) tdts(P) nf_nat_sip nf_conntrack_sip nf_nat_h323 nf_conntrack_h323 nf_nat_rtsp nf_conntrack_rtsp nf_nat_ftp nf_conntrack_ftp ip6table_mangle usblp thfsplus tntfs(P) tfat(P) ext2 ext4 jbd2 crc16 ext3 jbd mbcache usb_storage sg sd_mod scsi_wait_scan scsi_mod cdc_mbim qmi_wwan cdc_wdm cdc_ncm rndis_host cdc_ether asix cdc_acm usbnet mii ip6t_LOG ip6table_filter ohci_hcd ehci_hcd xhci_hcd usbcore jffs2 zlib_deflate nf_nat_pptp nf_conntrack
Aug 22 17:15:11 kernel: [<c0043ff8>] (unwind_backtrace+0x0/0xf8) from [<c0061d70>] (warn_slowpath_common+0x4c/0x64)
Aug 22 17:15:11 kernel: [<c0061d70>] (warn_slowpath_common+0x4c/0x64) from [<c0061e1c>] (warn_slowpath_fmt+0x30/0x40)
Aug 22 17:15:11 kernel: [<c0061e1c>] (warn_slowpath_fmt+0x30/0x40) from [<c020c980>] (dev_watchdog+0x26c/0x28c)
Aug 22 17:15:11 kernel: [<c020c980>] (dev_watchdog+0x26c/0x28c) from [<c006ce1c>] (run_timer_softirq+0x134/0x250)
Aug 22 17:15:11 kernel: [<c006ce1c>] (run_timer_softirq+0x134/0x250) from [<c0387b28>] (__do_softirq+0xac/0x148)
Aug 22 17:15:11 kernel: [<c0387b28>] (__do_softirq+0xac/0x148) from [<c00678dc>] (irq_exit+0x58/0x6c)
Aug 22 17:15:11 kernel: [<c00678dc>] (irq_exit+0x58/0x6c) from [<c003d204>] (do_local_timer+0x54/0x70)
Aug 22 17:15:11 kernel: [<c003d204>] (do_local_timer+0x54/0x70) from [<c03872a8>] (__irq_svc+0x48/0xe8)
Aug 22 17:15:11 kernel: Exception stack(0xcf843f98 to 0xcf843fe0)
Aug 22 17:15:11 kernel: 3f80: c8225f80 cf950600
Aug 22 17:15:11 kernel: 3fa0: cf843fe0 00000000 cf842000 c03e60a8 c03ceb80 c03e6214 00000000 413fc090
Aug 22 17:15:11 kernel: 3fc0: 0000001f 00000000 00000000 cf843fe0 c003ebe4 c003ebe8 60000013 ffffffff
Aug 22 17:15:11 kernel: [<c03872a8>] (__irq_svc+0x48/0xe8) from [<c003ebe8>] (default_idle+0x24/0x28)
Aug 22 17:15:11 kernel: [<c003ebe8>] (default_idle+0x24/0x28) from [<c003ed88>] (cpu_idle+0x70/0xa4)
Aug 22 17:15:11 kernel: [<c003ed88>] (cpu_idle+0x70/0xa4) from [<00008084>] (0x8084)
Aug 22 17:15:11 kernel: ---[ end trace 390a1e96f8b8f988 ]---
Full log HERE.
