Subnetting
Diveblaster
Hi
I wonder if its possible on a asus router gt-ac5300 to create a subnet for a single device. In this case a raspberry running ubuntu. The rest of the clients is on 192.168.1.x net.
So raspberry ip would be eg 192.168.10.2
I know howto setup this with second router but i wonder if its possible to do this without a second router.
Thx
Dive
Hi
Thx
Dive
Based on my experience only:-
- I would move the Pi onto the normal network - or -​
- Use the merlin version of code (if available) Load and Use YazWiFi and then connect via Wifi. -or-​
- just connect the pi to the guest wifi but that may stop local access.​
The latest version of 3.0.0.6 Native code has VLANS that may assist you and other "goodies"​
I dont know your Use Case so cant realy comment appart from bullet points.
This firmware is not available for GT-AC5300 model.
