Surfshark Wireguard
mdloading
I’ve been trying to use Wireguard on my Asuswrt-Merlin loaded RT-AX95Q with Surfshark VPN, but either some servers don’t work at all or the others just work for 2 minutes or so then completely stop having access to the internet.
OpenVPN works just fine with Surfshark, which is what I’m using right now, but I’ve tried 3-4 multiple servers and they give off the same issues as the others. I’ve played around with the Wireguard settings and nothing has changed.
I’m using Merlin firmware 388.2_2-beta2.
Beta firmware is unsupported. Report the issue to the firmware author for a chance to be fixed in stable release.
Broken functions are to be expected with beta builds. If you're not happy go back to the latest gnuton release, and report the problem you've had
