swap file creation
Feb 9 18:45:38 kernel: Adding 2097148k swap on /tmp/mnt/swap/myswap.swp. Priority:-1 extents:4 across:2244604k
Well, that says it's been added.
I think there is something going on behind the scenes that is causing conflict. I recommend a completely clean setup making sure to eliminate variables (i.e. only install one thing at a time, but make sure everything is stable between reboots before installing the next).
Well I tried to figure what is wrong but had no idea whats wrong so i removed all my scripts and reinstall them.
I suppose I may have 'accidently' reformat my USB causing skynet to not be able to startup which causes conflicts with diversion.
A clean install is now making all the scripts work together without any issues.
Thank you thelonelycoder & SomeWhereOverTheRainBow for the help.
