Switch from Cable WAN to Fiber WAN
Can you get ethernet to their ONT and go straight into your GT-AX6000, or you don't want to do that? Or bring the ONT into the house if there is an extra lenghth of fiber cable?
That's how mine is. Fiber line through the house, ONT inside the house straight into ethernet and into my GT-AX6000.
Well that would be preferable/ideal but I only have coax throughout the house. Thought about wiring cat 6 ethernet but a lot of work/expense and don't really need to with MoCA. Frontier connects the ONT to existing coax cable into house and then in master bedroom closet hub they connect MoCA adapter with ethernet to their Eero router/modem. Pretty much the same as Spectrum cable. I take the entrance point, connect POE filter to entrance point and splitter and split to two routers (main router is also split with cable modem). I have coax cable running through the house. Frontier installer said they only connect to existing cable>MoCA>Eero. They don't do anything else and they don't allow splitting (bs).
FRONTIER FIBER SETUP (500/500 Mbps @ $30/month)
OUTSIDE:
ONT (fiber)
↓ (coax - MoCA signal)
COAX ENTRY POINT (master bedroom closet):
Frontier's MoCA adapter
Eero Router
SPECTRUM CABLE SETUP (600/35 Mbps @ $50→$110/month)
OUTSIDE:
Spectrum coax line
POE Filter
Splitter (MoCA 2.5 compatible)
├─ Output 1 → Office coax
└─ Output 2 → Living room coax
OFFICE (2nd floor):
Coax outlet
2-way Splitter
├─ Output 1 →POE Filter→Cable Modem → Ethernet → GT-AX6000 #1 WAN port
└─ Output 2 → MoCA adapter #1 → Ethernet → GT-AX6000 #1 LAN port
GT-AX6000 #1 (Main Router - Asuswrt-Merlin)
└─ Computer hardwired via ethernet
LIVING ROOM:
Coax outlet → MoCA adapter #2 → Ethernet → GT-AX6000 #2 WAN port (AP Mode)
Equipment Used:
  • 2 MoCA adapters (ScreenBeam ECB7250K02s)
  • Cable modem (DOCSIS 3.1)
  • 2 POE filters (PPC 2520A GLP-1G70CWWS)
  • 2 splitters (entry point + office) (GE Digital 2-Way Coaxial Cable Splitter, 2.5 GHz 5-2500 MHz, RG6 Compatible, 33526)
