nvram set log_size=1024
nvram commit
service restart_logger
How to get a longer logging, to see e.g. what happened three days back?
Interesting! Is there a limit - or best-practice - for how much the size can be increased?To increase the size of the log file from 256kB to 1024kB (i.e. x4) SSH into the router an issue these commands:
Code:nvram set log_size=1024 nvram commit service restart_logger
Increasing the default system log size increases the amount of memory and jffs storage used. Old Asus routers had very little spare memory and storage available. That's not so much of a problem anymore for the RT-AX86U.Interesting! Is there a limit - or best-practice - for how much the size can be increased?
Why? This has nothing to do with what he's asking.The first thing I would do is flash RMerlin 386.5_0 and follow with a full reset.
It won't solve his problem.Maybe not,
That's not relevant to his question. Even when he does update his firmware he doesn't need to go through the whole reset and setup process.but running firmware with known issues doesn't make sense either.
Router is RT-AX86U, FW is 386.4
Except that's exactly the opposite of what you did. You don't understand his problem so your immediate reaction was to tell him to change his firmware and factory reset his router. You made no attempt to diagnose the problem.I prefer to get a complete picture by asking questions first, rather than assuming
Asking your stock question, doing nothing with the information provided and then posting your stock reply does nothing to try and understand the cause of the issue. Do you reformat your PC's hard drive and reinstall the OS every time you notice something you don't understand?No, it's not. You forget about post 2 and 5.
www.snbforums.com
Where can I find those detail level specification option now, that I have scribed installed? Any hints?Before I installed scribed, I could specify the level of detail that is logged (debug, information, warning etc.). After the scribed installation, that option is gone.
Where to find it with scribed installed?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
