System Time Incorrect
shonan
Can the time on the router be set manually?
The ntp page does not set the correct date or time.
MS
When the time doesn't come up correctly after a reboot or power reset, I've just gone in to Administration>System and manually entered a different ntp server then hit apply. I think there's a minor timing glitch in that the router looks for an ntp server before the WAN connection is established.
