Test wireless connection reliability, e.g. packet drops
Dan Dascalescu
What tools do people use to test the longer-term (hours) reliability of their high-bandwidth wireless connections through a router? I'm looking for something a little more sophisticated than "copy a large file" or "watch Netflix".
I know about iperf3 for measuring throughput, but I would like to stress test my router and measure how reliable wireless connections are over extended periods of time, to eliminate the router as a cause of my Play-Fi wireless speakers occasionally stopping playback for no discernible reason.
If I understand correctly, ping (ICMP) isn't the right tool for this, because it only sends very little data. What I'd want to simulate is traffic at X Mbps for Y hours (where X is, say, half the router's advertised bandwidth), and see at least how many packets have been dropped. Ideally, I'd also see a distribution of latencies, similar to what ab provides, e.g. X% of the packets made it in < Y ms.
Here's the same question for points:
https://superuser.com/questions/119...lity-of-wireless-connections-through-a-router
You could use the router's command-line tools like "wl", "ip", and "ifconfig" to view statistics that should include network errors & whatnot.
Though, let's say you see errors, what next? How do you fix it or know what's causing it?
My new microwave causes my WiFi to almost completely crash... :(
Is there any other wireless device that's having a problem aside from the Play-Fi device?
Yeah... trouble-shooting wireless is not fun... We're happy to help though. Good luck!
Under Windows, the following command will give you a lot of good information regarding dropped packets:
netstat -s
That's what I used a few years ago to diagnose a problem with my Ethernet cable. My transfer rate was abnormally low, running that command showed me a lot of retransmitted packets, which was solved after I recrimped my cable.
