connorm
very happy i can have all these clients +3 wired clients all using the network with no problem, i even have 3 xbox's all being used at once all open nat no problem
. now i just needa get some 9dbi antennas and hopefully will see some small improvements in the signal. thanks Merlin
SSID: "McCaffrey2.4GHz"
RSSI: 0 dBm SNR: 0 dB noise: -81 dBm Channel: 6
BSSID: 74: D0:2B:86:75:78 Capability: ESS ShortPre ShortSlot
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HT Capable:
Chanspec: 2.4GHz channel 6 20MHz (0x1006)
Primary channel: 6
HT Capabilities:
Supported MCS : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ]
Mode : AP Only
Stations List Rx/Tx Speed RSSI State
CC:08:E0:70:0B:AF 192.168.1.105 Connors-iPhone ??/39 Mbps -65 dBm assoc auth
00:1E:65:0F:8B:3E 192.168.1.118 WIN-3DMTNO93DVH ??/39 Mbps -69 dBm assoc auth
90:72:40:94:C9:00 192.168.1.113 DaniellsIphone5 24/52 Mbps -62 dBm assoc auth
00:03:7F:8E:B0:87 192.168.1.107 Danielles-PC ??/26 Mbps -55 dBm assoc auth
F0: DC:E2:C1:5E:3B 192.168.1.121 BriPhone 5/19 Mbps -73 dBm assoc auth
7C:ED:8D:FD:72:BD 192.168.1.119 * ??/65 Mbps -48 dBm assoc auth
DC:2B:61:50:9F:C9 192.168.1.117 Ballins-iphone ??/39 Mbps -64 dBm assoc auth
5C:59:48:63:10:30 192.168.1.110 Chrisitian ??/52 Mbps -57 dBm assoc auth
SSID: "McCaffrey5GHz"
RSSI: 0 dBm SNR: 0 dB noise: -83 dBm Channel: 157/80
BSSID: 74: D0:2B:86:75:7C Capability: ESS
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
VHT Capable:
Chanspec: 5GHz channel 155 80MHz (0xe29b)
Primary channel: 157
HT Capabilities:
VHT Capabilities:
Supported VHT (tx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Supported VHT (rx) Rates:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
90:27:E4:F8:FC:C6 192.168.1.108 Ren 270/13 Mbps -69 dBm assoc auth
88:1F:A1:0D:F6: D0 192.168.1.120 Jeffs-MBP 81/13 Mbps -79 dBm assoc auth
00:25:AE:65:00:24 192.168.1.102 * 150/81 Mbps -64 dBm assoc auth
58:55:CA:1E:B4:2F 192.168.1.104 Apple-TV 65/19 Mbps -72 dBm assoc auth
C:\Users\Connor>ping google.com
Pinging google.com [173.194.33.135] with 32 bytes of data:
Reply from 173.194.33.135: bytes=32 time=14ms TTL=56
Reply from 173.194.33.135: bytes=32 time=16ms TTL=56
Reply from 173.194.33.135: bytes=32 time=20ms TTL=56
Ping statistics for 173.194.33.135:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 20ms, Average = 16ms
also here is a test i ran with qos enabled set to 98 downstream 3.92 upstream at a rare moment when no one was using the internet, 4 am lol.
http://youtu.be/l_W6UqFcZ-E
HT Capable:
Primary channel: 6
HT Capabilities:
Mode : AP Only
VHT Capable:
HT Capabilities:
VHT Capabilities:
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
NSS: 1 MCS: 0-9
NSS: 2 MCS: 0-9
NSS: 3 MCS: 0-9
Mode : AP Only
