Solved The settings in /jffs/config/ are not being applied.
XIYO
Hello community,
I'm a non-English speaker, so I've used a translator. If my tone seems impolite, I apologize in advance.
my Environment
- hardware:
`AC88U`
- firmware:
`asuswrt-merlin 386.12`
- package:
`Entware armv7sf-k2.6`
I am currently testing what is mentioned in this document:
Custom Config Files on GitHub
I created a file in /jffs/configs/ called 'hosts' and filled it with '127.0.0.1 test'.
After rebooting and connecting to the router, when I try 'ping test', it can't find the destination.
I was under the impression that the content in /jffs/configs/hosts should also be reflected in /etc/hosts.
I have enabled 'Enable JFFS custom scripts and configs', and the scripts in /jffs/scripts are working fine.
Is my understanding incorrect?
