Solved TigerVPN Stopped working
ComputerSteve
I have tried to reset everything but this is all that happens when I reconfigure TigerVPN -- I verified the credentials it works. It's just not working on this router...
Jun 1 20:50:05 ovpn-client1[25591]: WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Jun 1 20:50:05 ovpn-client1[25591]: OpenVPN 2.5.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 19 2021
Jun 1 20:50:05 ovpn-client1[25591]: library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.08
Jun 1 20:50:05 ovpn-client1[25592]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jun 1 20:50:05 ovpn-client1[25592]: TCP/UDP: Preserving recently used remote address: [AF_INET]162.220.222.34:1194
Jun 1 20:50:05 ovpn-client1[25592]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jun 1 20:50:05 ovpn-client1[25592]: UDP link local: (not bound)
Jun 1 20:50:05 ovpn-client1[25592]: UDP link remote: [AF_INET]162.220.222.34:1194
Jun 1 20:50:05 ovpn-client1[25592]: TLS: Initial packet from [AF_INET]162.220.222.34:1194, sid=ddb00b14 12883b66
Jun 1 20:50:05 ovpn-client1[25592]: VERIFY OK: depth=1, C=SK, ST=Bratislava, L=Bratislava, O=Tiger At Work & Co. k. s., OU=tigerVPN, CN=tigerVPN, name=tigerVPN, emailAddress=[email protected]
Jun 1 20:50:05 ovpn-client1[25592]: VERIFY KU OK
Jun 1 20:50:05 ovpn-client1[25592]: Validating certificate extended key usage
Jun 1 20:50:05 ovpn-client1[25592]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jun 1 20:50:05 ovpn-client1[25592]: VERIFY EKU OK
Jun 1 20:50:05 ovpn-client1[25592]: VERIFY OK: depth=0, C=SK, ST=Bratislava, L=Bratislava, O=Tiger At Work & Co. k. s., OU=tigerVPN, CN=tigervpn.com, name=tigerVPN, emailAddress=[email protected]
Jun 1 20:50:05 ovpn-client1[25592]: Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA1
Jun 1 20:50:05 ovpn-client1[25592]: [tigervpn.com] Peer Connection Initiated with [AF_INET]162.220.222.34:1194
Jun 1 20:50:06 ovpn-client1[25592]: SENT CONTROL [tigervpn.com]: 'PUSH_REQUEST' (status=1)
Jun 1 20:50:06 ovpn-client1[25592]: AUTH: Received control message: AUTH_FAILED,Username or password incorrect
Jun 1 20:50:06 ovpn-client1[25592]: SIGTERM[soft,auth-failure] received, process exiting
I expanded logging does this help??
Jun 1 20:52:58 rc_service: httpd 472:notify_rc start_vpnclient1
Jun 1 20:52:58 custom_script: Running /jffs/scripts/service-event (args: start vpnclient1)
Jun 1 20:53:00 ovpn-client1[28153]: WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Jun 1 20:53:00 ovpn-client1[28153]: Current Parameter Settings:
Jun 1 20:53:00 ovpn-client1[28153]: config = 'config.ovpn'
Jun 1 20:53:00 ovpn-client1[28153]: mode = 0
Jun 1 20:53:00 ovpn-client1[28153]: persist_config = DISABLED
Jun 1 20:53:00 ovpn-client1[28153]: persist_mode = 1
Jun 1 20:53:00 ovpn-client1[28153]: show_ciphers = DISABLED
Jun 1 20:53:00 ovpn-client1[28153]: show_digests = DISABLED
Jun 1 20:53:00 ovpn-client1[28153]: show_engines = DISABLED
Jun 1 20:53:00 ovpn-client1[28153]: genkey = DISABLED
Jun 1 20:53:00 ovpn-client1[28153]: genkey_filename = '[UNDEF]'
Jun 1 20:53:00 ovpn-client1[28153]: NOTE: --mute triggered...
Jun 1 20:53:00 ovpn-client1[28153]: 227 variation(s) on previous 10 message(s) suppressed by --mute
Jun 1 20:53:00 ovpn-client1[28153]: OpenVPN 2.5.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on May 19 2021
Jun 1 20:53:00 ovpn-client1[28153]: library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.08
Jun 1 20:53:00 ovpn-client1[28171]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jun 1 20:53:00 ovpn-client1[28171]: LZO compression initializing
Jun 1 20:53:00 ovpn-client1[28171]: Control Channel MTU parms [ L:1622 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Jun 1 20:53:00 ovpn-client1[28171]: Data Channel MTU parms [ L:1622 D:1450 EF:122 EB:406 ET:0 EL:3 ]
Jun 1 20:53:00 ovpn-client1[28171]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-client'
Jun 1 20:53:00 ovpn-client1[28171]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-256-CBC,auth SHA1,keysize 256,key-method 2,tls-server'
Jun 1 20:53:00 ovpn-client1[28171]: TCP/UDP: Preserving recently used remote address: [AF_INET]162.220.222.34:1194
Jun 1 20:53:00 ovpn-client1[28171]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Jun 1 20:53:00 ovpn-client1[28171]: UDP link local: (not bound)
Jun 1 20:53:00 ovpn-client1[28171]: UDP link remote: [AF_INET]162.220.222.34:1194
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [14] to [AF_INET]162.220.222.34:1194: P_CONTROL_HARD_RESET_CLIENT_V2 kid=0 [ ] pid=0 DATA len=0
Jun 1 20:53:00 ovpn-client1[28171]: UDP READ [26] from [AF_INET]162.220.222.34:1194: P_CONTROL_HARD_RESET_SERVER_V2 kid=0 [ 0 ] pid=0 DATA len=0
Jun 1 20:53:00 ovpn-client1[28171]: TLS: Initial packet from [AF_INET]162.220.222.34:1194, sid=49cdd6c8 27d6abad
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [22] to [AF_INET]162.220.222.34:1194: P_ACK_V1 kid=0 [ 0 ]
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [291] to [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ ] pid=1 DATA len=277
Jun 1 20:53:00 ovpn-client1[28171]: UDP READ [1200] from [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ 1 ] pid=1 DATA len=1174
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [22] to [AF_INET]162.220.222.34:1194: P_ACK_V1 kid=0 [ 1 ]
Jun 1 20:53:00 ovpn-client1[28171]: UDP READ [1188] from [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ ] pid=2 DATA len=1174
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [22] to [AF_INET]162.220.222.34:1194: P_ACK_V1 kid=0 [ 2 ]
Jun 1 20:53:00 ovpn-client1[28171]: UDP READ [797] from [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ ] pid=3 DATA len=783
Jun 1 20:53:00 ovpn-client1[28171]: VERIFY OK: depth=1, C=SK, ST=Bratislava, L=Bratislava, O=Tiger At Work & Co. k. s., OU=tigerVPN, CN=tigerVPN, name=tigerVPN, emailAddress=[email protected]
Jun 1 20:53:00 ovpn-client1[28171]: VERIFY KU OK
Jun 1 20:53:00 ovpn-client1[28171]: Validating certificate extended key usage
Jun 1 20:53:00 ovpn-client1[28171]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jun 1 20:53:00 ovpn-client1[28171]: VERIFY EKU OK
Jun 1 20:53:00 ovpn-client1[28171]: VERIFY OK: depth=0, C=SK, ST=Bratislava, L=Bratislava, O=Tiger At Work & Co. k. s., OU=tigerVPN, CN=tigervpn.com, name=tigerVPN, emailAddress=[email protected]
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [152] to [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ 3 ] pid=2 DATA len=126
Jun 1 20:53:00 ovpn-client1[28171]: UDP READ [77] from [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ 2 ] pid=4 DATA len=51
Jun 1 20:53:00 ovpn-client1[28171]: UDP WRITE [528] to [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ 4 ] pid=3 DATA len=502
Jun 1 20:53:01 ovpn-client1[28171]: UDP READ [261] from [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ 3 ] pid=5 DATA len=235
Jun 1 20:53:01 ovpn-client1[28171]: UDP WRITE [22] to [AF_INET]162.220.222.34:1194: P_ACK_V1 kid=0 [ 5 ]
Jun 1 20:53:01 ovpn-client1[28171]: Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA1
Jun 1 20:53:01 ovpn-client1[28171]: [tigervpn.com] Peer Connection Initiated with [AF_INET]162.220.222.34:1194
Jun 1 20:53:02 ovpn-client1[28171]: SENT CONTROL [tigervpn.com]: 'PUSH_REQUEST' (status=1)
Jun 1 20:53:02 ovpn-client1[28171]: UDP WRITE [56] to [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ ] pid=4 DATA len=42
Jun 1 20:53:02 ovpn-client1[28171]: UDP READ [22] from [AF_INET]162.220.222.34:1194: P_ACK_V1 kid=0 [ 4 ]
Jun 1 20:53:02 ovpn-client1[28171]: UDP READ [86] from [AF_INET]162.220.222.34:1194: P_CONTROL_V1 kid=0 [ ] pid=6 DATA len=72
Jun 1 20:53:02 ovpn-client1[28171]: AUTH: Received control message: AUTH_FAILED,Username or password incorrect
Jun 1 20:53:02 ovpn-client1[28171]: TCP/UDP: Closing socket
Jun 1 20:53:02 ovpn-client1[28171]: SIGTERM[soft,auth-failure] received, process exiting
Is this 'solved' or is there a question remaining here?
So it technically isn't solved lol.. Yesterday it stopped working. I just switched to my backup VPN & its working. Idk why it stopped.
